I picked up this saw at my local Lowe's the day after Christmas, and initially I was very pleased with it. However, the motor seemed to take a long time to spool up, the alignment of the blade to the miter slots was around 0.015" (and measured differently depending on what slot I measured from), and there was a slight hump in the table right above the arbor. After talking with Delta, I brought the table saw back to Lowe's and traded for another one. I'm still in the midst of setting it up all over again, but things are looking cheerier. The motor starts right up, and the alignment is only out by 0.003" (same from each slot). My only complaint is that there seems to be the same little rise on the table in the same spot. But I don't think its worth starting all over again. My father manages a machine shop and I work at a pretty large service shop myself. I'm hoping between the two of us we can address any issue there might be with flatness.
I can report that putting the saw together a second time is faster. I recommend putting on the front and back rails first, then the extension wings afterward. I feel like there was less fiddling using this method.!
