Decked Out Ridgid Model R4511 Table Saw
239640 Views 124 Replies 41 Participants Last post by  crzy4wood
Introduction and Background
After moving into a different house with a very small shop, I had to leave behind my beloved General Model 350 3HP cabinet saw with Delta Unifence and 50 inch rails…....... :-(
However, after much research and positive reviews on LJ and other forums, I purchased a Ridgid Model R4511 Hybrid Table Saw in 2009….... :) I was much impressed by this well engineered tool with so many features offered at such a favorable price, especially with the sale going on at Home Depot at the time.
After using the saw for about a year or so, it became apparent that some improvements could be made to better utilize the space in my shop and adapt the saw to my own personal preferences. Some of the modifications were intended to correct perceived design deficiencies; some were equipment upgrades; and some were just to suit my own personal preferences.
This multi-part blog will describe these modifications and some of the logic behind them. As many of you have this wonderful saw, you may find some of these modifications worthy of implementing in your own shop. I would like to thank all of the folks who have so freely shared their ideas and expertise on this forum. Some of the changes I made were inspired by ideas shared on the LJ forums and others.
The topics to be covered in this blog series include the following:
  • Redesigned Mobile Base
  • Improved Dust Collection
  • On-Board Storage
  • Upgraded Rip Fence
  • Rear Outfeed Table
  • Downdraft Side Extension Table
  • Relocated Tilt Handwheel - Design Considerations
  • Relocated Tilt Handwheel - Finally Making It Happen
  • Tilt Indicator Redesign
  • Final Modifications
  • The Unveiling - Before and After
Please come along with me on this adventure. I think you will find it interesting, and even if you have a different model tablesaw, you might just find some ideas you can put to work in your own shop-and hopefully improve upon!
41 - 60 of 125 Posts
On-Board Storage
My present shop is very small - approximately 9 1/2 ft. x 20 ft. With tools along both long walls, it is more like a woodworking corridor….......... :) It does take some planning of operating sequences! Needless to say, I don't whack up any 4' x 8' sheet goods - that's what my sawhorses and Skilsaw out in the carport are for! However, I am thankful to have even a small shop space to putter in, and most of my projects will be small items.
That said, real estate in my shop is a very precious commodity. Consequently, I designed the new mobile base for this Model R4511 with provisions to add modular storage cabinets.
The left side of this saw table extends about 12 inches beyond the cabinet. As designed, the only residents of this space were the Tilt Handwheel and the fence storage brackets.
Machine Composite material Engineering Metal Event
To make the best use of this space, I was willing to give up the fence storage brackets and try to figure out some way to relocate the Tilt Handwheel. So I designed a five-drawer cabinet to fit this space under the table extension and between the caster outriggers on the mobile base. Cabinet construction was mostly Baltic Birch plywood, with various other varieties used in less visible places. Visible edges on the front of the cabinet were faced with 1/2" poplar. The 1/2" back panel of the cabinet was secured to the saw cabinet with screws.
Wood Rectangle Gas Cabinetry Metal
All of the drawers are 10 1/2" deep with 1/2" Baltic Birch frames and most have 5mm Birch plywood underlayment bottoms. The drawer sides are dadoed into the drawer fronts, which, I discovered later, made them much harder to get aligned with one another on installation. If I were doing it again, I would make separate drawer fronts. All drawers are mounted on ball bearing full extension slides with 1" overtravel. I found a lot of these slides for $4/pair, so I couldn't pass them up.
Wood Rectangle Gadget Gas Box
The large drawer was designed to hold my saw blades, and has a 1/2" thick BB ply bottom to accommodate the extra weight. The drawer will store 11 saw blades. In addition, there is also space along the side of the blade compartment for my 8" dado set and my 8" box joint cutter set.
Light Packing materials Rectangle Automotive design Wood
In the matching space on the right side of the saw cabinet, I designed a small cabinet with a drawer mounted on the same full extension ball bearing slides with overtravel. Construction of this cabinet was the same as for the cabinet on the left side of the mobile base. The space above this cabinet is taken up by the motor cover. Tho small, this drawer will still be useful for storing miscellaneous accessories and tooling.
Bumper Wood Automotive exterior Drawer Rectangle
As mentioned earlier, I designed the new mobile base with a deep drawer in its front panel. This drawer is about 20" deep and is mounted on full extension ball bearing slides. The large size of this drawer will accommodate storage of bulky items like my Delta Tenoning Jig, Zero Clearance Inserts, etc.
Bumper Asphalt Road surface Wood Automotive exterior
So, that's it for the on-board storage provisions. Thanks for coming along - but there is much more to come…............
Could you post picture of the whole thing?
Thank you.
On-Board Storage
Yes pictures please and more on tilt wheel
On-Board Storage
Aha-- the mysterious moving Tilt Handwheel….......... Sorry folks, but that's a secret that will have to wait…....... :) Stay tuned….............it's on the agenda. In the meantime, how would you do it? There are several possibilities, some of which have been discussed here on LJ…...........
Similarly, we can't post a finished project picture yet…............That would be like reading the last page of a mystery novel…...................!!
But in the meantime, I wish you all a blessed Christmas and a Happy New Year.
On-Board Storage
BOOOOO….. i just want a pic of the saw on the mobile base.
Upgraded Rip Fence
For those who don't have the Ridgid Model R4511 or have never seen one, the stock fence is a T-square type - sort of a mini-Biesemeyer configuration, very loosely speaking. This configuration is somewhat similar to the Delta T-2, which a number of folks have purchased to replace the stock fence on this saw. It has a square tube front rail, bolted to a formed steel angle which is screwed to the front of the granite table top. For ease of shipping, the front rail is split in two pieces, with a plastic coupler fitting between the two halves. Like the Biesemeyer, the fence body straddles the rail and a cam lock mechanism pulls the body against the steel tube rail. This mechanism seems to lock the fence position quite well. The fence itself is a 2" square steel tube, which has a "hook" fitting on the rear end that catches underneath the rear angle rail.
Automotive lighting Water Automotive exterior Vehicle Asphalt
There have been quite a number of folks who have found the original rip fence on the Model R4511 to meet their needs and expectations very well. And of course there have been a fair number of folks who have had difficulties with the fence - issues related to the two piece front rail, alignment front to back, excessive height off the table, etc. I didn't have any major issues with the fence except the excessive height off the table, altho I think the 2" square tube is too small to be useful for a lot of ripping applications on thicker/longer stock. In addition, I could not get used to the debris-catching space between the front rail tube and the rail support angle - it seemed like I was always losing a pencil in that space and it was always full of sawdust!
My biggest problem with the original fence was a historical one! I had been using a Delta Unifence for the last 20 years or so, and I just couldn't get comfortable using a difference fence. In addition to the "perceived deficiencies" mentioned above, I missed some of the features of the Unifence - especially the unique feature of the Unifence which allows the fence extrusion to be retracted to a position in front of the blade so it can be used as a stop block for uniform length cross cuts.
The Delta Unifence I purchased for use on the Model R4511 had a 30" rail, allowing a maximum cut of 30" to the right of the blade and 9" to the left. The total length of the front rail was about 60". Unfortunately, since I purchased the one for this project, it seems like the Unifence is either no longer made or is in very short supply. I suspect that since Delta bought Biesemeyer, they would rather sell only the Bies. - which is indeed an excellent fence, as many of you can probably attest.
The Unifence is a three-piece rip fence - an extruded aluminum front rail, a machined cast aluminum body, and an extruded "L"-shaped aluminum fence. The fence body is supported by the front rail, and a nylon tipped "foot" that rests on the table top - there is no attachment to the rear rail. A steel bar running in a tee slot in the front of the rail is cam locked to the face of rail to lock the fence position. The fence extrusion can be positioned on either side of the fence body, allowing left-of-blade cutting.
The fence extrusion can be mounted to the body in two ways. To accommodate this feature, two index lines are provided on the clear plastic scale cursor, with an icon to show which one applies -therefore, it is possible to read the wrong cursor line if one isn't paying attention…... :-( DAMHIKT...........!!The following photo shows the fence extrusion in the Low Fence Mode, (my favorite) providing a 1/2" high fence surface and allowing space for hand holding the workpiece without obstruction from the higher part of the fence.
Output device Gas Bumper Wood Office equipment
This view shows the fence positioned in the High Fence Mode providing a 3 1/2" fence face.
Output device Gas Engineering Automotive exterior Machine
The addition of an After Market Auxiliary Fence extrusion allows the use of feather boards or other hold down devices. However, the use of such devices does require the fence extrusion to be clamped down to the table or rear rail, which is easily accomplished.
Wood Automotive exterior Gas Bumper Machine
Mounting of the Unifence proved to be challenging. The Unifence was designed to be attached to the front face of a cast iron table, which typically has a flange around the edges of the table. Bolts with heads inside the flange and nuts inside integral tee slots in the back face of the fence extrusion are used to secure the fence to the table. However, the Model R4511 has a solid granite table with no edge flanges. So I had to dream up an alternate mounting method.
This installation required the mounting of a new steel rail support angle to the front edge of the table, using the original hole pattern, which I transferred from the original fence rail - the cheapo transfer punch set from Harbor Freight worked like a champ for this application. I used 1/8" x 2" x 2" angle stock from Home Depot. In retrospect, I wish I had used 3/16" or even 1/4" thick stock, which would have made it more rigid. The thinner stock is adequate, however - sometimes bigger is better! In addition, I replaced the stock rear fence support angle with a 1/8" x 1 1/2" x 1 1/2" steel angle I had lying around the shop to provide support for a right hand table extension to fill the space between the fence rails outboard of the granite table.
To accommodate the radius between the rail angle legs, I fabricated a maple filler. The filler was attached to the rail extrusion with 1/4" machine screws and either speed nuts and hex nuts. The speed nuts were used to accommodate the large upper tee slot, which was designed for 3/8" hex nuts in a normal installation. I didn't have room for the large heads of 3/8" FH machine screws in the face of the filler.
Surveillance camera Rectangle Wood Gas Technology
This view shows the rail support angle, filler, and rail extrusion installed on the front of the granite table. Note that there is no channel between the table and the fence rail to collect debris - or lose pencils…. :)
Rectangle Automotive exterior Electric blue Auto part Tints and shades
The Unifence rail extrusion was attached with 1/4" machine screws tapped into the bottom surface of the fence rail, as shown in this view. Altho the fence rail extending beyond the edge of the right hand granite table extension was unsupported, it is so rigid as to not pose a problem.
Wood Gas Fixture Hardwood Bumper
Since installing the Unifence, I have felt much more at home using the saw-kinda like putting on an old pair of slippers…........ :)
Well, that's about it for this chapter. Stay tuned, there is lots more to come….....................
Upgraded Rip Fence
Nice upgrade. I have the 4511 and put an Incra fence on. Gotta love craigslist.
Upgraded Rip Fence
Thanks. I have heard that the Incra fence is a dandy. What a jump from the OEM Ridgid fence, huh! Good show!
Upgraded Rip Fence
Paul,
Do you still have your R4511?
I had one .
I sold it for about $200.00 than I paid for new.
I bought a used Unisaw for $400.00 and I rebuilt it.
Upgraded Rip Fence
Hi Bert,
Yes, I still have the R4511. So far, it meets my needs very well. I am not overly impressed with the granite top, but it does solve the rust problem.
The Unisaw is the old standby-that is a good price you paid for it. I don't have room in my shop for one. In my old shop I had a General Model 350, which was the Canadian equivalent of the Unisaw. That was a great saw.
Upgraded Rip Fence
http://lumberjocks.com/b2rtch/blog/29941
http://lumberjocks.com/b2rtch/blog/31439
Upgraded Rip Fence
You do very nice work, Bert. That is quite a shop you have there. Congratulations!
Upgraded Rip Fence
To repair/refurbish old equipment is what I like to do best more that to use it.
Upgraded Rip Fence
Hi there,
Not sure if you're still monitoring this page Paul, but if so could you tell me how long the front fence rail is on the original R4511 supplied fence? I am hoping to purchase one in the near future, and for planning purposes with my shop it would be helpful to know how long the rail was/is. You might not still have it, in which case would you say it was longer or shorter than the Delta you have on there now? Thanks so much for the advice.
Upgraded Rip Fence
Hi Bailey,
The original fence rail was about 67 1/2" long. The saw specifications state that it will cut 20 inches to the left of the blade and 30 inches to the right.
Tho I like the saw, I would have preferred to have a cast iron top instead of the granite. The granite will chip and scratch and makes the saw weight much heavier than cast iron. I am not happy with the miter gage slots in the granite top. The edges of the slots are not polished and quickly wear the plastic adjustment washers on the Incra miter gage bars. Also, you can't use any magnetic tool accessories with the granite top.
If you can find one, I would recommend the previous model, R3650, which a lot of folks seemed to like. Some folks also like the follow on model, R4512, which is the current model. Check out both of the saws in the Reviews section of LJ. Both of these models have cast iron tops.
Hope this helps.
Upgraded Rip Fence
so can the Delta BC50T2 50 in. Universal Biesemeyer Fence and Rail System be mounted on a Ridgid Model R4511 granite top?
Upgraded Rip Fence
I am not familiar with the Delta BC50T2, altho I think a lot of folks have successfully retrofitted their table saws with this model.
As noted on page 14 of this manual the front rail of the stock fence is bolted to a steel support angle (Front Rail Holder) which is bolted to the front of the granite top.
If the stock rail mounting angle is too small for the Delta fence, it is not difficult to replace the angle with at least a 1/4" thick one (which I did on my R4511 mod) and transfer the hole pattern over to the new support angle.
If you make this update successfully, please post your results here so others can benefit from your experience.
Rear Outfeed Table
One of the useful additions to a table saw is a Rear Outfeed Table. In my old shop I made a folding rear outfeed table for my General 350 cabinet saw that was something like 24" deep and 48" wide. Altho it worked well, it took up a lot of space (which I had available in that shop), but it made a great assembly table.
However, in my new small, narrow, shop, I had to rethink a design suitable for the space I had available. I knew a folding design probably wouldn't work because I didn't have room to move the saw out from the wall and still get around behind it to fold/unfold such a design. So I opted for a fixed table design.
Since the new Delta Unifence I installed on my Model R4511 hangs out over the back of the granite saw table about 12 inches, I decided to use this space for the Rear Outfeed Table. I was willing to give away a little width space in the shop for the convenience of the outfeed table. It is surprising how useful such a narrow table can be in supporting most of the normal rip cuts I do for my projects. The saw can be rotated away from the wall for longer cuts and those that require an auxiliary outfeed stand. Also the space under this table works well for my back mounted DC duct and flex hose.
This short, simple, outfeed table is 13" deep x 20" wide and constructed of Baltic Birch plywood with a laminate top. The miter gage clearance slots extend clear to the back of the table - I have found that blind ended slots tend to collect debris and are hard to clean. You sharp-eyed folks will notice that the table tilts down slightly at the back. That was intentional and can be corrected by adjustment screws which I have not yet installed in the back mounting. So far I haven't found the tilt to be a problem. The front edge of the outfeed table is slightly below the saw table so that pieces don't catch coming off the saw.
Rectangle Wood Flooring Floor Wood stain
The Rear Outfeed Table is bolted to the back of the saw table and is supported by a gusseted bracket. Any adjustment screws could be threaded into the spreader bar between the gussets. The spreader bar just rests against the back panel of the saw cabinet.
Wood Wood stain Rectangle Gas Hardwood
I know this hasn't been a very exciting chapter in this blog, but I included it as part of the photo documentation of this project. The next section should prove to be more interesting…..........Stay tuned!
Rear Outfeed Table
I am still here
Rear Outfeed Table
Great idea and design Paul. I think this is a very useful addition for this saw, as there is not much table behind the blade.
A Breezy Side Extension Table
A Side Extension Table was required to fill the space between the front and rear fence support rails, outboard of the saw table. Some folks install a solid panel, as I did on my General 350 cabinet saw in my old shop because I had a multi-drawer cabinet underneath. Many folks use this space for a router table, which is a great way to add another tool to the shop without eating up any floor space. We have seen many great examples of this type of router table here on the LJ forums - it seems there are a lot of clever folks in the community willing to share their ideas and designs! I love looking at all of the various configurations and the skookum Yankee ingenuity! Whoops - and including our non-Yankee constituents…...... :)
In that vein, I would like to thank the forum member who I think is here on LJ, for the inspiration for my take on a Side Extension Table. I copied a photo of your design, but I was unable to find your post when I was writing this blog - but whoever you are, thanks for sharing such a novel idea - you will recognize my version of your design!
I couldn't bear to waste the space between the fence rails, but I didn't need a router table since I will be building a free standing one soon. So when I saw the design of a Downdraft Sanding Extension Table , all the bells and lights went off! So here is my version of this accessory.
The downdraft table is surrounded by a removable fence system to help contain the sanding dust. Threaded tooling knobs with matching inserts secure the fence to the table and the fence components to one another. The table top is 1/2" Baltic Birch plywood covered in high pressure laminate. There are (432) 3/8" holes on a 1" x 1" grid, that were plunge routed through the top and finished with slight chamfers both sides to improve airflow. This hole pattern was designed to produce about 800 CFM airflow from my 3HP DC. A piece of perforated plastic shelf liner will be used under the workpiece when sanding.
Table Wood Rectangle Sports equipment Automotive exterior
The dust collection box is 21" wide and 27" deep, with 5" high maple side members. The bottom of the box is 1/2" plywood. Sloped baffles, on all four sides, made from 5mm Birch underlayment plywood, channel the dust down into a 1 1/2" x 14" center dust collection slot in the bottom of the box. Note the same aluminum duct tape I used to attach the baffles inside the saw cabinet in the earlier discussion.
Rectangle Wood Cosmetics Tints and shades Flooring
A 6" diameter sheet metal right angle furnace boot with a 6" diameter PVC coupling was attached to the bottom of the dust collection box. The bar supported by the allthread pieces is a bumper to protect the thin sheet metal duct from damage when I roll my shop vacuum in under the dust box for storage.
Automotive design Automotive exterior Bumper Automotive exhaust Gas
This view shows the dust collection box installed between the fence rails. The laminate covered, perforated, 1/2" plywood top panel (slid aside) installs flush with the top of the box.
Cosmetics Hood Rectangle Tints and shades Wood
This view shows the modular fence components. They are designed so that one or both of the short sides can be removed to accommodate long pieces. If both short sides were removed, the long side would be clamped to the Unifence. However, most of the work I do should fit within the fences. The installation hardware is stored in one of the on-board storage drawers when not in use.
Trunk Rectangle Bumper Automotive exterior Office equipment
The modular fence components were designed to be stored underneath the dust collection box when not in use. Note the angle clips used to secure the dust collection box to the fence rails.
Wood Gas Machine Bumper Creative arts
Again, my thanks to the forum member who posted the original design. One of the things I most enjoy about the LJ forum and others is the sharing of ideas that others can use and hopefully improve upon and/or adapt for their own use. What a great woodworking community!!
Well, that's about it for this chapter. Hang in there….....................there's a lot more to come. Thanks for stopping by. Please feel free to leave any comments or constructive criticisms. All questions will be answered.
