1 - 18 of 18 Posts
Discussion Starter · #1 ·
dado for shelves
this is a jig to do dados on the RAS .
the object , is to make accurate and repeatable cuts for shelving and whatnot .
and not cut the saw table or the backstop .
as with all of my RAS jigs , they must do these things ,
and leave the table , backstop and arm at 90deg. ,
so it does not get out of alignment .
this first pic. shows the crosscut dado .
this pic. is the grove with shelf ( imagine ) the depth of cut is regulated by
raising or lowering the arm , and this jig has its own stop , that can be replaced
if it gets messed up .
this shot is the jig in it's normal state , not to big and heavy,
it is high enough to clear the saw fence .
it is 11 1/4 " wide , by 32" long .
this is the jig with the wings extended , for longer boards ,
over all , it is 80" in length , and can be simply moved in and out by hand .
this is the registry dowels , that fit in holes in the table .
the bottom edge is shy of the table fence for sawdust ,
and the wings also for this reason .
put the jig on table and slide to drop it in to it's place .
these are the holes for various other jigs that drop into place also .
when all is said and done , the saw is ready to crosscut or rip ,
and there are no clunks missing in the table or fence,
and the arm has not moved from its square position .
the construction of the jig , 4 groves 3/8" deep x 3/4" wide
are dadoed into 2 pieces of pb ( or whatever ) and the boards
screwed together and the ends cut for the wing rests .
4 - 3/4' dowels are in the square channels formed ,
( see ma , i can put a round peg in a square hole ) !
and 2 dowels are attached to one wing , and 2 to the other .
this whole thing is screwed together , no glue .
in case i need to repair or upgrade it later .
the stop is screwed to the back , and is replaceable .
now that we got this far , i'm starting to think of stops for repeat cuts .
why it's a good idea to screw this together without glue !
as usual call jim , and he can answer all your questions . :cool:
( thanks jim . i got to go split firewood now )
dado for shelves
Brother, you are truly amazing!
You HAVE to be the most "favorited" guy on this web site!
dado for shelves
David:
A great looking jig. Makes me wish I had a RAS again.
dado for shelves
Wow this is quite a contraption.
Looks like I wouldn't have enough room in my small shop for this, but wish I could have one.
David you are the master jigger. LOL
Lisa
dado for shelves
David,
You are duly crowned "King of Jigs"
dado for shelves
Karson, I have to agree with you. I said the same thing last night. Wish I had mine back too. David, you got some great ideas and they work fantastic.
dado for shelves
Hey David,
Well though jig buddy. Nice too.
How do you register you dower from the jig to the table. Do you drill them through the jig and the table at once when the jig is in final position ready for production?
By the way, few weeks ago I relocated my RAS, alone. If you're interested, check how I did it by myself
http://atelierdubricoleur.spaces.live.com/blog/cns!2ED8F7A23848B4AE!1535.entry
Best,
Serge
http://www.atelierdubricoleur.spaces.live.com
Discussion Starter · #8 ·
dado for shelves
serge yes , after everything is done on the jigs ,
i clamp them to the table and drill down thru everything ,
them dowel the jig ,this keeps them centered where i want them .
nice move on your saw ,
you have to think like that when
you work alone .
In Loving Memory
dado for shelves
Great blog David! Really well thought out jigs. I am trying to figure out how to apply some of your jig thinking to my shop.
Discussion Starter · #10 ·
dado for shelves
good morning mike .
up early today ,
aren't we ?
thanks ,
i may have to build a barn
for the jigs someday !
so i can work
in the shop !
dado for shelves
One fart smeller, I mean smart feller! Nice!
Discussion Starter · #12 ·
dado for shelves
must be all that cheese wiff from australia ?
dado for shelves
Hey Bud
This is a cool layout but what else would we expect form the master Patron. Good work David.
BTW all your calls are on call waiting LOL
Discussion Starter · #14 ·
dado for shelves
just the same dado from the table saw .
dado for shelves
Hey David,
You're always there when time comes to answer a question, even after several days. You're a great man to count on !
Happy Holidays buddy. And to your loved ones.
Best,
Serge
dado for shelves
Very Clever, David!
dado for shelves
Hi David:
Looks like your jig raises the workpiece a couple inches from the table surface and allows you to cut through the jig's attached fence instead of the permanent one you have on your very long table. Is that right or is there some other function I'm not understanding?
regards, Kerry
Discussion Starter · #18 ·
dado for shelves
yes , you are corect kerry
the jig has its own back fence
that gets chewed up with the dado blades
i just stacked them to 3/4" and the lesser stack
has a clear path form the wider one
that fence can be replaced if it gets to chewed up
what i like about it is being able to line my dado cuts
with the fence cut (at least on one side of the fence cut out)
since it is a dado the table jig doesn't get cut at all
just the fence
1 - 18 of 18 Posts
