1 - 20 of 98 Posts
Discussion Starter · #1 ·
Zig Zag Cutting Board - How To:
For those of you who asked me for a tutorial on how to make the zig zag legless vegetable death table (cutting board), here is my best shot. I am far too impatient to take photos when I work, so I decided to illustrate the process using some good old Adobe PhotoShop. I hope you find this useful and informative.
I will outline the process in 10 steps below. I have assumed that when viewing these steps that basic woodworking skills are familiar to you. If you have questions, or run into snags, PM me and I'll do my best to help out.
If you want to see what these boards look like, take a look at my projects. There are a few in there.
Keep in mind that because these are endgrain boards, you should ideally chose the original boards with interesting endgrain. Makes sense right?
Rectangle Wood Slope Font Wood stain
I typically measure all of my initial boards and add a few inches. I'd rather end up with scrap pieces, then a scrapped piece. I went big on the 26" length, but after you do a few of these you can create your own ideal measurements. I also try to start out with boards of thicknesses larger than 3/4", but it was easier math for the illustration to use 3/4" thickness.
You can make boards of all sizes. I'm limited to a 12" thickness planer, so that's why I am illustrating 7 sticks of each species. Again, experiment with different sizes, so long as the individual sticks are twice as wide as they are thick.
Wood Rectangle Font Parallel Hardwood
I can't stress enough the importance of only mating two sticks at a time. No three sticks should be mated with glue. Use your preferred clamping methods, but make sure these are nice and tight. You don't want any gaps for bacteria to hide in.
Rectangle Wood Wood stain Flooring Floor
After these sticks dry, pull them out of the clamps. They are ready to be planed down a bit to make sure they are all even and dimensional. I tape them all (squeeze-out side up) together and run them through the planer.
Table Rectangle Wood Slope Wood stain
After these are planed, it's important to pull them apart and make sure they are dimensional (as wide as they are tall). If they differ, run them through the planer individually until they are square.
Table Furniture Rectangle Wood Wood stain
In order to get the zig zag pattern, you have to cut the original sticks in half so that you can make two sets of patterns. This is the tricky part that I was never able to show folks without illustrations. We'll call them Set A and Set B for this demo.
Furniture Rectangle Wood Wood stain Flooring
Now, the reason I went with 26" as the original length is so that this next step allows you to be creative. You can make a very long (two maybe) board that is thin, or make a very heavy-duty board. Thickness is up to you.
Rectangle Wood Font Wood stain Hardwood
Now you are ready for your final glue-up. Take your time and really see this board for what it will become. Look at the end grains and make sure they are uniform. I have flipped boards upside down and noticed this too late. And remember "ENDGRAINS UP!" Maybe I'll make a TShirt with that phrase on it one day.
Rectangle Brick Font Wood Soil
After the glue dries, you should be left with a not-square-yet board.
Rectangle Font Metal Pattern Parallel
Trim edges using any method you prefer. I run mine across my crosscut sled to make sure they are as true as possible.
I hope this tutorial was helpful and that you are inspired to try one of these boards out.
UPDATE: I have created an additional blog entry with some patterns to try out using the techniques listed above. Check out Zig Zag Cutting Board Patterns - Inspirational
Very well detailed and explained… even I can follow this…
Discussion Starter · #3 ·
Thanks Larry.
This looks to be one of the easiest to follow how to blogs I have seen. I will have to try this again. My first attempt at this pattern, http://lumberjocks.com/projects/37671 (third pic) , did not turn out like this. I realised I had a problem after the 1st glue up and went another direction. I will have to give this another shot. Thanks.
Scott
Your Zig-Zag board is awesome, and if "Board Master Larry" thinks the blog is good, that is like having Sam Maloof like your rocker!
I'm putting this in my favorites for future use.
Thanks.
Thank you great detail
A very clear how to and much needed. Here is how I messed up my attempt pic #5 still not sure where I went wrong…. I'll get it right next time… Thanks
Thanks. I printed this and will keep in handy in the shop. I have 9 different boards ready to cut for some cutting boards. This will be a design to try.
Robert
Thanks for being a sharing LJ, bet we see some beauty soon. Nice blog well explained…BC
That was VERY WELL done! Thanks for taking the time and effort to lay that out for us. I know I'm keeping a copy in my file!
Pictures…..who needs stinkin pictures. Okay this is my shot at humor. This is very well done. Thanks for taking the time to put this together. I like others will be keeping it for the future. Thanks again.
Excellent! Can you glue the whole boards together first before cutting them into 7 sticks? That way you only have to align two boards during the glue-up instead of 14. Once they're glued, can't you just cut the lamination into 7 strips? I'm under the gun to make a cutting board for the monster-in-law, so your info is greatly appreciated.
This is a nice tutorial that even I can follow. I definately will have to favorite this blog as this looks like something I would like to try.
The only comment that I would have on this is that I, personally, would be hesitant to remove dried glue beads with my planer. I have tried that once with my jointer many years ago and succeeded in nicking all three knives. I would opt to remove the dried glue with scraping and sanding before using the planer to thickness the board.
Discussion Starter · #14 ·
Wow. I'm glad I put this together then. Thank you all for the comments. Replies to a few below.
CaptainSkully - yes you can, great point. You can totally glue the two original boards together. I haven't tried that but it sure makes a lot of sense. I tend to do something one way and never waiver. My only comment on that is that i haven't been able to get my hands on extra wide boards, so typically I'm not starting with two boards.usually a few cuts of the same board. Good luck on your board. Make sure to post it.
Scott Bryan - any method you prefer to use on glue. I don't claim to know a whole lot about planer blades, and that's probably the reason my blades are looking rough these days. I put all my tools through the ringer. Again, I am a very impatient woodworker. I have precious few hours in my shop between my crazy day job and little kids. You have an excellent point that should be noted. Thanks for the tip. I need to invest in a scraper.
As you can see from the comments above, there are most likely ways to improve the methods. Please keep the comments coming. Were paving a great path together for all LJs who stumble across this blog and are inspired to give this board a shot.
Thanks guys.
This is a very good tutorial! Concise and clearly explained. Thanks for posting. I favorited this post.
Erwin, Jacksonville, FL
Thanks for taking the time to put this together. Great job on both the board and the tutorial.
For me is easier taking photos than editing this kind of stuff. I will need 100 tutorials on Photoshop to get something of this sort out !! LOL
Wow, thanks heaps for that easy to follow instructions maybe I will be able to cross another thing off the "to do list" with your help.
Thank you very much. I know that it must have taken you a great deal of time to put that together for us. A sign of a great artist is a willingness to teach.
Sweet.
I like this design. I am going to have to try it.
Thanks,
Steve
thanks man thats awesome
1 - 20 of 98 Posts
