This is my first post here, so apologies if not correct.
In a nutshell: I'm getting crowned cuts when crosscutting a thick piece of hickory.
The details: I'm making a picture frame out of hickory, which is 2.25" thick and 3.25" wide. I'm making the miter cuts on a Delta Professional table saw (meticulously matinained and tuned), via a custom dedicated 45 degree miter sled. I've done this dozens of times, with many different wood types, and have achieved excellent results with this setup. What's changed is that now I'm using thicker stock. The resulting cut is perfect in every way except there is a crown (convex lobe) right in the middle of the cut (see attached image). This is completely baffling me. I've been using Freud commercial blades, 50T, 60T 80T and 90T, in both full and thin kerfs. I don't believe the issue is blade 'wobble', as the crown is perfectly centered within the cut. Blade 'wobble' generally causes off-centered and/or multiple lobes. I've tried increasing/decreasing the feed rate and various amounts of stock removal per cut, all with the exact same results. The crown/lobe is not considerable, only 0.5mm, but that's unacceptable for a mitered picture frame. Anyone ideas about how to tackle this would be greatly appreciated.
