Hey all. I've got a Craftsman 113.298 that I picked up for free off craigslist recently (really lucky find). Couldn't really give it a once over when picking it up since it was out on the curb and I wanted to snag it before wasting a trip a few towns over. Got it home and it's got a bit of rust that was very easily buffed out, and a link belt that makes this baby run better and quieter than the Crapsman I stole from my dad that's been sitting in a box since the early 2000's.
However, I have a problem. Firstly, I can't get the blade past around 89 degrees. And when trying to diagnose that issue, I discovered another: the crank shaft that changes the blade angle is busted in some way. At certain points it's incredibly hard to turn, at others it spins freely and is loose enough to shake side to side. That's when I discovered a possible culprit: what looks like some kind of deformity in the housing for the ball bearing on the cranking end of the shaft (excuse me lack of mechanical know-how and terminology). See the pictures below:
As I turn the crank and it hits some resistance, the ball piece begins to wiggle out of the housing until it's totally free. That's when the shaft spins freely and is loose enough for side to side motion. I suspect the role of this housing it to act as a counterforce so that the shaft can move the blade arbor along the trunnion as you crank the wheel. Because of the deformity, it can't do this to the necessary degree.
So, this deformed housing and blade tilt mechanism definitely seems to be an issue that needs to be fixed, but I don't have enough experience to say whether it's directly related to the blade being unable to reach a true 90 degrees. Possibly it's something to do with inaccuracies in the original setup?
Anyways, this is my first time getting my hands dirty with a table saw, or really any piece of machinery, so I'm pretty lost here. Any and all help would be greatly appreciated. Thanks!
