1 - 11 of 11 Posts
I guys. Does cold weather effect the start up of an air compressor? My All Power Quietzone acted like the motor was stuck when I tried to start it up the other day, a very cold day. It is brand new and I am in contact with the mnaufactuer. I would appreciate anyones input. Thanks, Wookie.
Oilless compressors will start pretty good, even in subzero climates. I know this for a fact because I have used my oilles compressors at -5° and -7° with no problems.
Oil lubricated compressors will have a really tough time though. You can get a lighter weight winter grade oil for them but they are still affected by the cold.
I am a remodeling contractor and my oilless compressors end up getting shared with the other guys because their oil lubricated compressors won't start, they act just as you described.
The biggest drawback to the oilless compressors are that they are really loud compared to an oil lubed unit.
II picked up a new compressor the first week in January and had the same thing happen. My basement is not heated and when it drops below 50 it sometimes won't start on the first try. I moved it into a new room I built in the basement with the boiler and immediately it started running better. You may just have a cold problem and not a bad compressor.
Your unloader valve, which some compressors have, allows the electric motor to come up to speed under reduced pressure. The orifice may be clogged with ice, especially if moving it to a warm area instantly makes it start up easily.
I have this problem a lot in the winter working outside. I usually just open the drains in the tanks and let it run for a minit with them open to warm up. Once it gets fired it never seems to have a problem the rest of the day.
Sometimes I have to reset the fuse a couple times to get it going. This can't be good for the compressor but when you got to work you just do it. Been doing this for at least 5 years with this compressor and still working fine.
Good luck
Mike
On any compressor you can remove the quick connect and install a tee with a valve, which will act like an unloader. Open the valve and release any pressure before you try to start and leave open. Many large compressors will operate this way to allow the oil to begin lubricating before the real work begins. once the compressor has ran for 30 seconds or a minute close the valve and go to work. If you are going to change the oil to a lighter weight oil DO NOT use motor oil!!! Use a high quality non-detergent oil. The detergents in motor oil can break down the rings and seals in your compressor causing major headaches. Most automotive parts stores (napa or the like) carry non-detergent compressor oil, just ask them about it. Also when the weather warms up make sure to put the proper weight oil back in. Also in cold weather it is critical to drain off any condensate from the tank before quitting time each day. I recently saw a tank at work rupture due to corrosion of the tank bottom. Scary! Good Luck
Andy
This compressor is electric and oil-less / lubricated for life. Single digit temps at night here lately in good ol' IL. with below zero windchills. What I like about this unit is that it is quit, 55db and lightweight. The manufactuer is in the process of sending me a return/exchange. I hate to return it because I got the last one the retailer had and I got a really good deal on it. I would like to hang on to it but if it is not safe I better unload it. I'll move it inside for a couple days and start it unloaded as suggested. It is made in China just like everything else. Thanks for the replys guys. You Jocks always come through.
Being a retired Firefighter, we constantly use equipment that goes from one temperature extreme to the other. For best results, never leave air in the storage tanks, drain after every use before you put them away. If portable, raise the end of the compressor up from the drain valve when draining. This will ensure any moisture will get out of your tank. Always use the proper oil for the tools you own. Always oil your tools prior to each use.
Invest in a heavy duty Extension Cord 12ga. Ok, 10 ga. Better, 8 ga. Best. I use old arc welders cables and never make the length more than 10 feet. Better to have a long hose and raise the pressure than starve the motor for electricity. Better yet, rewire the old flimsy cord direct from outlet to compressor.
P.S. Wookie, I live in Illinois. No what you mean about the cooold daaamp air.
Thanks Tom1 and UnionLabel. I have been letting it warm up with the petcock all the way open and seems to helping a lot. I have a very heavy ext. cord. It is from the hospital where mama works and was used on various life support equip. I Don't know what gauge it is but every time I whip it out to use it someone always asks if I can get another. UnionLabel, thanks for your service. You guys are abreed apart.
1 - 11 of 11 Posts
