I did check out your post and commented. Great job.!!! Am I to understand you spoke of two products; the Osmo Poly X and also Osmo Pole X #3034?? Is this available at the usual suspects - HD, Lowes, Ace? Thank you.
Osmo Poly X #3043 (clear satin) for both - I just left off the 3043 the second time that I mentioned it. You probably will not find it at the stores you mentioned, but you will find it at stores specializing in woodworking. And on-line is a good way to buy it.
It is made in Germany and at first glance, it seems expensive. But actually it is not. Two reasons; only two coats are needed (most polyurethanes need three coats). The second reason is that a little goes a long, long way! It takes less than half the volume of Osmo PolyX than it would take for polyurethane.
There are various ways to apply it but the best way is to use a white Norton non-abrasive pad. Rub it in as you would to wax a car. After ten minutes, using a clean Norton pad wipe off the excess. Let it set overnight, then buff it with 0000 steel wool. Then apply a second coat, following the same steps as with the first coat. When that second coat has dried, you're done. You don't need to buff the second coat after it dries with 0000 steel wool.
It is important to buff with 0000 steel wool after the first coat has dried. If you don't, the final finish will be flat with no sheen.
This finish is so easy to apply. Runs or brush marks will not be an issue. Unlike polyurethane, a year later if you need to touch up a spot, it is very easy to blend in; just buff the area with 0000 steel wool and rub in more Osmo PolyX. And the best thing of all is the beautiful, natural looking finish that it gives.
