1 - 4 of 4 Posts
I WAS WONDERING IF THEIR IS ANYONE OUT THEIR WHO HAS MASTERED THEIR HOME BUILT CNC MACHINE YET? AND IF SO IF THEY WOULD BE WILLING TO BUILD ONE?? I WOULD BE GLAD TO PAY SOMEONE TO BUILD ME ONE. I DON'T HAVE THE COMPUTER KNOWLEDGE NOR THE TIME TO BUILD ONE..
LET ME KNOW.. THANK YOU..
There are several bolt together kits available that would have you up and running within about a day or so of bolting components together.
Check out probotics.com or finelineautomation.com for complete kits in the $1000-$1500 range after adding electronics. Far a few more dollars you could buy a ready to run system like the CNC Shark at Rockler.
It all depends on your price range and what size/quality you are looking for. What are you planning to make with a CNC router?
You really need to identify what size of stock you want to cut, thickness of the stock and whether it needs to be basic 2-D or has to be 3-D. A CNC to handle cutting 4' by 8' sheet goods to build cabinet carcases is a different world than a bench top to cut templates or engrave jewelry boxes.
Also, economy CAD/CNC/CAM software isn't as easy as sending any graphic to a printer. Having some background around CAD or a machine shop will help considerably, else you will have a pretty extensive learning curve.
Building your own or having one locally made takes away any factory support. If you go this route, make sure you use a design that has an active forum online to reference for questions that will come up. The same goes for choosing a software package.
Steve.
If you don't have the computer knowledge to build one, than how will you use it? Building a machine is easy, but many people hit a wall with the software when it comes time to using it.
As someone who programs and runs $100,00 routers for my day job, I can tell you that anyone who thinks they have mastered their CNC router doesn't try new things. There are always new things to learn.
1 - 4 of 4 Posts
