WoodRiver - Set Up Block Set (Rating: 4)
I picked this up at a local Woodcraft (Item #148454) for ~$32. Got it mostly to speed up set-ups on the router and table saw. As soon as I got it, I measured each block with my digital caliper. Each block measured within half a thousandth of spec, except for the 1/2" and the 1-2-3 block. The half inch block measures 0.502" by 0.506" and the 3" side of the 1-2-3 measures a few thousandths over, also. Maybe that's too much for high precision machining, but it's more than adequate for woodworking. Also, for $32 you'd be hard pressed to find a more accurate set.
Whats in the box: 1-2-3 block, 0.0625" (1/16"), 0.125" (1/8"), 0.25" (1/4"), 0.5" (1/2") and 0.75" (3/4") gauge blocks. Plastic case.
