1 - 8 of 8 Posts
Discussion Starter · #1 ·
First steps
I decided to create a chess set in which the pieces would be the 'names' of each piece-I'm pretty new to woodworking, so this is a learn as I go process. I've started by doing some basic prototyping of the 'pawns'
pawn1
Here's the first go at them-the 'real' ones will have some sort of symbol at the top, to make the board easier to 'read'. They will also likely be thinner, and won't be made out of scrap plywood, which splinters and misbehaves when futzing with the scroll saw (note the malformed 'w').
I tried a second prototype, but didn't like the lack of distinction between the 'a' and 'w', but used a few ideas in the final template. Here you can see some early sketches, the second prototype, and final template:
pawn2
I doubt I'll go into this level of detail here with each piece, but I thought it interesting to show the initial process. I'm just using a scroll saw to do this work.
First steps
pawn1
pawn2
A very interesting approach and is likely to be very time consuming. I'm looking forward to following this blog as well as the finished set
First steps
pawn1
pawn2
unique. I like it.
First steps
pawn1
pawn2
Unique Idea can't wait to see the finished product. Welcome to LJs.
Discussion Starter · #5 ·
First steps
pawn1
pawn2
Yeah, I suspect it will take some time, but hopefully will be rewarding; if someone has wood suggestions for the 'real' pieces, I'm all ears. It should be fairly inexpensive, and 'forgiving'. I'll probably make a mistake or two with the sawing, and don't want to be crying that I've ruined at $20 3" piece of wood or whatnot. :).
Discussion Starter · #6 ·
Two new prototypes
Finished my 'Knight' and 'Rook' prototypes:
rookandkinght
They are closer to the actual thickness I have in mind-note too you can see the symbols at the top of the pieces, now. Also note the extra space below each word, which will be used to add stabilizers.
Today I'm going off to select/ask about the wood for the finished pieces. There are a lot of pawns to make, so I'll do those while I work on the prototypes for the remaining pieces.
Two new prototypes
rookandkinght
Keep on trucking one step at a time.Can't wait to see the finished set.
Two new prototypes
rookandkinght
Awesome idea! Definitely looking forward to seeing the finished product.
1 - 8 of 8 Posts
