Charles Mackintosh Inspired Computer Desk
12978 Views 27 Replies 6 Participants Last post by  JimYoung
10
Getting Started - Design and SketchUp model
My youngest daughter asked for a computer desk for her 17th birthday. Well, it was last week so I'm already behind.
She wanted something that had Japanese influences. After looking at countless pictures over the past several months I was looking at a side table on Kevin Rodel's website and she saw it and immediately decided that was the look she wanted. The table is described as a "contemporary Asian inspired Arts and Crafts with roots in several old masters".
Table Furniture Flowerpot Flower Plant
The site also has a desk with similar details that was inspired by Charles Rennie Mackintosh, one of my favorite styles.
Table Furniture Rectangle Wood Desk
She was sold on the idea. Meanwhile, I've been learning just enough SketchUp that I can draw up a 3D model and generate the necessary drawings to build the desk.
I must say I'm very happy with SketchUp. The basics were easy to learn, certainly easier than when I learned CAD. Part of the process of making the model is creating the joinery so it will all fit together. I was able to find and correct numerous little details that normally would get missed, only to cause problems in the shop. I was also able to adjust and correct details that didn't look right with a few clicks of the mouse rather than getting it built only to realize the proportions were off and the piece doesn't work. Lastly, I was able to show her what it would look like before I start building.
There are some tricky parts including the inset chamfered edge detail on the top and the rounded leg posts. I'm also going to make my first major foray into inlay (after I watch Kevin Rodel's videos).
Kevin Rodel - Thank you again and again for all of your helpful online writings and videos as well as some magnificent furniture designs.
Table Rectangle Electric blue Font Wood
Table Furniture Rectangle Electric blue Coffee table
Dimensions: 50×24x30, ebonized walnut, satin clear coat, with glass panels from my friend Alex at Glass Heritage that will be inspired by some more of Kevin Rodel's glass work.
Brown Building Wood Wood stain Beam
I have a large stack of walnut planed and waiting for me to start. I'll be starting with the side lattice/grid, then move on to the legs, drawers, front and back panels, then the top.
1 - 20 of 28 Posts
10
I made a simplified version that captured the form without the glass. Check it out here:
http://lumberjocks.com/projects/151282
Love me some Rodel & Mackintosh so am looking forward to this project! You've also obviously done something right if your 17 year old has such a great aesthetic. Make sure to send her some coasters for her roommates in college…
Chuck - I found your version a while back when I was first looking to see if anyone else had built it. Even with the simplified design, it still holds true to the original design.
Getting started takes longer than you think
Armed with prints from the SketchUp model I headed out to the shop shortly after posting the first blog in this series on the Mackintosh desk for my daughter. I was a bit optimistic. After pulling several walnut boards out of the stack I quickly realized I needed to finish plane them to the appropriate thickness and run them across the jointer to get a straight edge.
Wood Rectangle Flooring Stairs Floor
That took a couple of weekends to plane the ~200 BF between all of the other endless day-to-day projects around the house and yard. As a bonus, I was able to mulch a large area with the walnut chips that came off the planer. Walnut mulch seems to deter weeds from growing which is a bonus.
I also had plenty of practice using the Wixey digital thickness gauge that I put on the planer this spring. I can't say enough good things about the Wixey products.
Jigsaw Gas Machine tool Bumper Machine
At any rate I think I have enough 3/4, 4/4, and 1-1/8" (top) to complete the project without having to plane more. Since the wood is #2 common there will be a lot of waste due to cracks, splits, knots, twisting, and all of the other imperfections that comes with lower quality (and less expensive) grades of wood. I'm not sure that the lower cost offsets the increased waste and extra time spent working around the imperfections.
Wood Hardwood Lumber Plywood Composite material
In addition to the planing and jointing, I pulled out the 8/4 slabs I was planning to use for the legs and looked them over. Ughh - they are almost completely worthless. The boards are all twisted, with splits, checking, and worst of all, 2 of the boards have metal fragments that look like bullets embedded in them.
Time for Plan B. I went to the big box store, bought a large bottle of Gorilla glue and started gluing 1" boards together to make the 8/4 thickness for the legs.
Wood Bottle Gas Engineering Machine
Shelf Wood Shelving Wall Hardwood
At the same time I realized that there were several changes that I needed to make to the model to provide a better sense of proportion for the desk. While I was making all of the changes to the SketchUp model, I watched some more of the "How-To" DVD's and learned how to make better shop drawings.
The legs will be 2" x 2-1/2"x 29" so I cut them 3" wide and 30" long so there was some room to clean them up after gluing. After the glue set up I scraped off the excess glue, ran the glue edge along the jointer, ripped the board to width and then cut them to length and gave them a preliminary sanding.
While I was at the table saw I ripped the 2" boards for the left and right side grids. The grids are 13" tall and 19-1/2" long.
Finally, I think I'm ready to start this project.
Table Wood Flooring Floor Wood stain
All of the pieces for the grid were cut to length and sanded. I set up a dado stack to cut the 1" notches for the grid. The openings will be 2" and the grid will be 1" thick. After I dry fit the grids, I think it might have looked better with 2-1/2" openings.
Rectangle Wood Font Flooring Wood stain
Wood Floor Flooring Wood stain Hardwood
Tire Wheel Wood Floor Rectangle
The grid pieces will be ebonized and a first coat of finish applied to the interior faces before the grids are glued together and sanded flush. I will also be starting the mortises for the legs and then work out the method to achieve the rounded profile I want using some new router bits.
Can't wait to see the progress, I'm a big Mackintosh fan.
I feel your pain with respect to the #2 common, but aside from the "fatal" defects, I often find a lot more interesting grain, especially if there is a once stable knot that can be strategically located.
Love the smell of working with walnut 8^)
I love projects like this! Especially since it inspired you to learn how to do the do shop drawings in SketchUp. These are the kinds of that really take your woodworking to the next level.
splinter - walnut and cherry smell both great when working with them.
I tend to appreciate all of the "defects" in common grades. This batch of wood looks like it was left overs that have been sitting around for years.
Captain - I try to learn something new on every project. I learn more on some projects than others. SketchUp hasn't been too hard to learn since I have a lot of experience with CAD.
Gridlocked and Broke Down
It's been a while longer than I intended since I added to the build write up (sorry I'm old school and can't call it a blog). Since I have drawings of all of the pieces from Sketch-Up I decided the best way to keep track of things was to hang them on the wall above my work area.
Gas Font Space Circle Paint
Before I started cutting all of the various mortises in the leg pieces I pre-finished the grids.
Since the grids have 2" openings, getting a good smooth finish inside them would be difficult and time consuming. Iron acetate is used to ebonize the wood by turning the tannins in the wood black.
After a light sanding, I followed up by wiping on a couple of coats of Arm-R-Seal blended 5 to 1 with ebony stain. I added the stain to the finish since the intermediate sanding was exposing un-ebonized wood, especially on the corners.
I will be using this approach with most of the pieces since it makes the final finish work much easier and the sanding less tedious.
Here are the grid pieces after ebonizing and 2 coats of Arm-R-Seal:
Wood Floor Building Flooring Rectangle
From there, I glued up the grids:
Automotive tire Automotive design Motor vehicle Building Engineering
After the grids were glued up I needed to level off the outside faces. I started by using a random orbit sander and quickly demolished a couple of the sanding disks because they kept catching on the edges and ripping the paper. I needed a better plan.
Since the grids are 13" wide I thought I might be able to run them through the Dewalt 735 planer using the finish cut setting (175 cuts/in) and get them cleaned up. I flipped one of the grids over to the back in case things didn't turn out like I wanted. First pass went well with no tear out. I eased the depth down by 1/4 turn (1/64") and started the second cut. I heard a loud CLUNK as the back end was exiting the planer. The maple piece that was glued into the grid came u-glued and was still in the planer. Maybe this approach wasn't the best idea???
After quickly raising the cutter head and shutting it off I pulled the piece out. It was undamaged. However, when I turned the planer back on the infeed and out feed rollers would not turn. After several hours of looking on the internet I was able to piece together enough different Youtube videos and commentary to find out the likely problem and where to look.
The outfeed roller has a sprocket that is connected to the main drive shaft.
Product Automotive tire Audio equipment Bumper Automotive exterior
The infeed roller is driven by the outfeed roller via sprockets and a chain on the other side of the planer.
Wheel Automotive tire Train Motor vehicle Bumper
The outfeed roller sprocket key appears to have sheared off.
Crankset Tool Bicycle part Automotive tire Gear
Parts are on order and fortunately, I don't need the planer to conitnue work on the desk.
Meanwhile, I decided to try the 4×24 belt sander to sand everything flush. It worked quite well without ripping any belts. While I was at it, I sanded the legs and drawer frame pieces.
Next up - Mortises and Tenons
Time for some Leg Work
I'm on a roll this morning. Things are quiet around the house and I haven't gotten distracted so it looks like I will get 2 installments of the project progress written up.
There are a number of mortises that will be required for the legs. Initially, I was considering using a plunge router with a template jig that slid over the legs but decided that approach would be too tedious. I also wanted to figure out a suitable approach to using the router table to make mortise cuts.
All of the mortises will be 1/2" wide and 1/2" deep for consistency and so I won't have to change bits and adjust the bit height once I get it set.
The grids will attach to the legs using a loose tenon or spline depending on what you want to call it. For the first set of mortises, I set up the router table using a square, a spacer, and a digital height gauge.
Wood Bumper Material property Gas Automotive exterior
The cast iron router table I own isn't compatible with any of the after market router fences like Incra or the Woodpeckers fence. I've come up with a couple of different ways to set up the fence so it is parallel to the miter slot. A square set along the edge of the table and held tightly against the fence will keep things mostly square.
Bumper Automotive exterior Office equipment Gas Auto part
With some fiddling and minor adjusting the fence can be set up square to the miter slot and spaced correctly to the bit.
I also set up a stop, using a scrap piece of wood cut to the length of the mortise. The miter bar touches the edge of the bit and the scrap piece is placed against the miter bar. The stop is set against the far end of the scrap piece and slid against the fence (hence the need for a way to get the fence parallel to the miter slot) and clamped to the router table.
Wood Floor Flooring Hardwood Gas
All of the mortises are laid out on the pieces so I don't get confused. There are 8 legs with mirror image 3" mortises on 4 of them, and mirror image 12" long mortises to accept the loose tenon for the grids. There are also 2-1/2" mortises cut in the legs for the spacer piece on the lower section of the legs. A white lead pencil shows up well on the walnut.
Wood Rectangle Floor Flooring Hardwood
From there it is a simple matter of cutting the mortises.
Wood Interior design Flooring Floor Hardwood
After cutting all of the mortises on the router and squaring them off with a corner chisel, I set up the dado stack on the table saw for the tenons on the drawer frame back and sides. Previously, I had cut the drawer frame back and sides to length and height. While I had the dado stack set up I also cut the slide slots and the mortises in the back frame to accept the side frames.
Everything was dry assembled to check fit:
Building Wood Shelving Shelf House
Up to this point, things have been straightforward and not overly challenging. The legs still have a lot of router work to achieve the rounded look I'm trying for. I've ordered a couple of round over style bits with large diameter curves in them (1-1/2") that should work. Hopefully, I can work out a good approach using some scraps as test pieces. This will definitely require a well thought out, cautious approach since the bits are so big.
Looking great!
That desk will have some serious "heft", can't wait until you get some finish applied to see that wood really pop.
Looks good. FWIW, I used a Jesada 'Queen Anne' bit on my legs to get that gradual rounding. Much easier to use than one of those monster panel raisers or complex profile bits.
Chuck - I have a bit lie the one you mention. That is one of the options I'm going to try. I'll definitely take lots of pictures on this one so folks can see what the various bits can do. I wish the bit manufacturers could show actual pieces with the profiles cut in them to give a better sense of what the profile looks like on an actual piece of wood.
Just a little off the top
The legs on the desk are one of the unique features that set it apart from just another desk. Each leg is has an inside and an outside piece. They are spaced 2" apart with the grids providing the spacing for the top, and a 2"x3" spacer for the lower portion.
After the mortises were cut into the legs and the leg sections were dry fit together in the last post, the edge details for the legs needed to be finalized. The outside piece is rounded over from the front to the outside edge. The outside edge is also rounded over into the back edge.
The inside piece will have the same front round over from the front side to the inside face, but the other edges will remain square.
After ordering several router bits and trying out different looks I settled on a 1-1/2" round over for the front edge and a handrail round over bit for the side profile. These are a couple of big bits!!
Wood Lamp Tints and shades Font Metal
Wood Automotive exterior Gas Bumper Auto part
To keep track of everything I numbered the leg sets and then also drew the relative profiles on the ends of the pieces. I always label pieces and lay out the cuts so I can keep track of everything. Making a mistake with a layout is easy to fix with a bit of sandpaper to sand off the lines. Realizing you missed something right after you cut it means you get to start over.
Brown Rectangle Wood Mesh Floor
After routering all of the 1-1/2" round overs, I marked the pieces that needed the second round over profile and ran them across the router.
Wood Rectangle Beige Material property Hardwood
While I was at the router table I made the corbels that will support the table top. The corbels were rough cut on the band saw then finished on the router using a template jig.
Wood Countertop Flooring Floor Composite material
All of the pieces were sanded. ebonized with iron sulfate, and then lightly sanded again, then the legs for each side were glued up. After the glue set I wiped on 2 coats of a blend of 4 parts General Finishes Seal-A-Cell and 1 part ebony stain. The stain should help with any thin spots from sanding.
The Seal-A-Cell is a bit of an experiment to see if it is any different from the Arm-R-Seal. I can't really tell a difference at this point. It might wipe on a little better than the Arm-R-Seal (??).
Wood Gas Hardwood Cylinder Machine
I still need to figure out the curves for the drawer fronts and back apron and finish them before I can glue-up the base. That is next on my list now that the planer is fixed. The drawer boxes need to be made as well, and finally, the top is still nothing more than a stack of dimensioned lumber.
Looking great!
That last bit barely fits your table, good call on the profile, very nice.
Should be done in no time eh? 8^(
Very nice. Good practice on marking everything.
Drawers
Seems like there is always something that needs to be taken care of during the time I could be working on my wood working projects. I have to say I'm jealous of some of the other LJ's and how quickly they can move through a project. Still, I have managed to finish the construction phase of the desk.
The drawers are standard dovetail construction with a 1/4" walnut bottom slid into a slot 1/4" off the bottom edge of the drawer. Here's my version of a dovetail cutting station. The plywood keeps the chips from flying all over the shop. The router rest and vacuum attachment works quite well.
Wood Table Flooring Gas Hardwood
The sides are 3/4" walnut with a 1/2 slot for the drawer slides. I used an ogee edge on the top of drawers to lighten up the top profile. Turned out better than I expected. I also partially prefinished the interior of the drawers by ebonizing the wood then wiping a couple of coats of Seal-cell mixed with ebony stain on the pieces.
Prefinishing the inside makes the whole finishing process easier. All of the pieces are flat, no corners to make sanding difficult, no vertical faces that might have a sag in the finish. I'll simply turn the drawer upside down when I finish the outside and not have to worry about messing up the interior finish. The interior will get a final coat along with everything else when I set up the sprayer.
Wood Rectangle Floor Flooring Gas
Rather than make the drawer slides from walnut, I dug up some scrap pieces of UHMW. They are screwed into slots in the drawer frame. This should eliminate any binding up caused by humidity.
Rectangle Automotive exterior Gas Wood Auto part
I was also able to cut the drawer slots tighter to the slide dimension so there won't be the usual up/down play in the drawer as it is opened/closed. All in all I hope it is a better approach than the usual wood slide.
I changed the drawer front design to match the arch profile on the back stretcher. The original design made the drawer fronts look like eyes while the new design reinforces the Asian feel of the piece.
Wood Gas Hardwood Table Flooring
Drawers
Hi Earl,
I think you're making great progress. Sometimes getting pulled away from a project can help keep you motivated to get back at it.
This is going to be a great piece.
Topping things off
I saved the best for last, or certainly the most challenging part of the project, the desk top. This is a close up of the top profile at the leg from Kevin Rodel's desk.
Furniture Table Property Wood Rectangle
At first glance it doesn't seem that difficult, cut some panels and glue them together, then cut a profile on the edge. I came up with a combination of steps using the table saw to cut the 45 deg bevel and then remove the remaining material with a 1/2 router bit. Unfortunately, wouldn't work on tapered leg sections or the curved ends.
I spent many long hours looking through the various websites to find a router bit that could cut the set back beveled edge. The beveled router bits all had a guide bearing on top of the bit which wouldn't work. I also found a beveled bit without a guide bearing which would work for the sides, but not the curved ends. I needed a beveled bit with a shoulder and a guide bushing on top. Raised panel bits seemed the way to go. MLCS had what I was looking for.
Wood Font Flooring Rectangle Art
As I was pondering my options I also decided that the best approach would be to router the profile on a 4" wide piece of stock, mortise the squares, then glue them to the top panel. After the bit arrived (another beast of a bit) I cut a test piece.
Table Wood Drill Tool Handheld power drill
It looked good so I set up the router and cut the side profiles. Everything went extremely well (whew). I moved on to mortising the square holes. I used the test piece to set up and test out the mortises and proceeded to cut them.
Wood Tool Flooring Hardwood Gas
Wood Tool Composite material Gas Hardwood
From there, it was a matter of gluing the top pieces together, making sure the profiles lined up with the legs correctly.
That left the curved end profiles. I didn't want to use the inside curve template from the drawers and rely on keeping the bit tight up against it so I used it to trace an outside curve template, rough cut it on the bandsaw and sanded it smooth. The template was clamped on the desk top and I used a 3/4" x 1-3/4" pattern bit (another large bit). Generally, I don't like to use such a large bit when I'm using the hand held 2.25 HP Bosch router but the need to keep the template clamped to the top and the size of the top made this the best approach.
Automotive tire Gas Bicycle part Machine Tire
Wood Flooring Floor Composite material Automotive exterior
Brown Rectangle Wood Flooring Floor
I had to set up the router table to cut the profile with a rather unconventional support for the top since it was so large and heavy. I couldn't use the profile bit in the hand held router since it wouldn't fit and I wouldn't feel safe with a bit that large in it.
Wood Table Flooring Floor Hardwood
After going through a couple of dry runs to figure out how to best maneuver the top to make a smooth cut, everything went as planned and the top profile was finished. Whew!!!
Working with large router bits seemed to be the theme during this project, something I haven't done much of before. I'm proud to say I didn't ruin anything or get hurt in the process. The adage of measure twice, cut once applies, or in this case, think things through and make test pieces before trying it on the actual wood for the project.
I'm in the process of sanding, staining, and prefinishing everything before it is sprayed with a final top coat and everything is assembled. The glass panels for the legs should be ready soon as well.
Table Wood Tire Flooring Floor
Topping things off
Super-cool, Earl! Way more work than mine-but the results are fantastic. The challenge I've found with the large panel bits is getting the profile even if the wood is a bit warped. Looks like you're mastering that too!
1 - 20 of 28 Posts
