1 - 7 of 7 Posts
· Registered
Just as the title said have a cane that has leather wrap on it and need to put a topcoat on the whole thing. I've read that water based poly is a good topcoat but was wondering about oil based. I've used lacquer in the past and it worked well but want the extra protection poly provides.
Thanks
· Registered
As long as the leather will not move in the slightest, it should be OK. Not certain, but oilbased might have more elasticity and, I think, more protection.
· Registered
I have done this with rope to make a rope trim around my bedroom. (nautical theme) As long as it is fairly rigid should not be a problem. I did find if I tried to bend the trim after the poly had dried it would crack. It has been up for 10+ years and never given me an issue. The rope did soak up the poly so many coats were required to get the look I wanted.
· Registered
I've used oil based poly over leather, denim and rope (firmly secured/glued so there would not be any movement) and never had a problem.
1 - 7 of 7 Posts
