So I've decided to build myself a sharpener. Lately I've been restoring some old tools and after flattening and sharpening a set of old chisels and a plane iron I decided that I've had enough with the sharpening by hand. So I found a great plan for a flat grinder by Nick Engler from his Sharpening book.
The best thing about it was that I have practically all the parts I need just laying around.
The motor I have is from an old evaporative cooler. It's perfect too, because it's a 2 speed, so I can grind slow and extra slow. 1725/1140 rpm. The problem with this motor is: 1. The plug is weird and 2. Because of the 2 speed option, there's an extra lead in the back.
Here are the leads in the back: I circled each one in yellow.
My questions are how can I wire this so that I can utilize the two speed option during use; and also how do I convert this to a regular 3 prong plug?
I was thinking I can run the 4 wires (3 leads: [L=low C=common H=high] 1 ground) to a switch control box of some sort and then from there run a regular 14/3 cord to any outlet. But I seem to have an extra wire that needs to be eliminated somehow to go from 14/4 to 14/3. Is there some "magic" in the switch box that can take care of that?
Here's a pic of the wiring diagram:
Here are the motor specifications:
Thanks for any help you can provide me. I'm proficient in wood only and get easily confused when it comes to electrical…but I'm working on that.
-Dan
Just cut that weird plug off of the the cord that already exists on the motor. You ought to verify this with an ohmeter, but from your picture it looks like the colors in that cord are:
Green - frame ground
Red - "L"
Black - "H"
White - "C"
Wire the leads from a regular 3-prong 110V cord so that:
Green - ground, goes directly to frame ground on the motor
White - neutral, goes to "C" terminal on the motor
Black - line, goes to the center terminal of the switch that ScottN suggested.
The "H" and "L" terminals of the motor should go to the outside terminals of the switch. This way, center position of the switch will be OFF, flip one way for HI speed and flip the other way for LO speed.
Sounded like you were struggling with the electrical issues; is that enough detail for you?
You guys are awesome. Thanks for the collaborative effort! And EEngineer I really appreciate the detail. I wouldn't have been able to figure out how to use that switch properly without your description. And I thought this was going to be at least more difficult or more expensive! $2.99, I can handle that.
I'll post pics from the build as soon as I finish. I've got to wait a couple days 'cause I've got some family visiting now, but once they're gone…
Ok, so I went to the electrical supply store to buy the switch and the guy there told me that that switch wasn't rated for motor use and that the in-rush current would be too high for that switch. The motor rated switches he had there were very expensive, so I decided to look around on the net for something cheaper. But as I'm searching, I'm finding thousands of different switches and I'm not sure what I need exactly.
What I do know:
I need:
1. Motor rated
2. 20A @ 115v
3. 3 position (On-Off-On) I think this is called "double throw" ?
What I don't know:
1. What is the difference between the poles. Double pole vs. single pole and does it matter which one I use for this application?
2. Some switches I've found have 6 connections in the back instead of 3. If I get one of those can I just ignore the other extra 3 and hook it up like EEngineer said, or do I need a different switch altogether?
If you don't use a switch that is motor rated, it will destroy the contacts starting and stopping it in short order.
If you don't want to spend the money for a good switch, you need to decide if you really need 2 speeds. the single pole switch will be a lot cheaper. Or, you could use a couple small open faced relays that are rated for the motor load. They will be about $12 each. How much do you want to spend on getting this 2 speed operatiion going?
You want a single pole - double throw switch. You could use the double pole - double throw, but those are usually for 208/220v applications. Connect the black from the 14/3 supply cord to the common terminal of the switch and connect the black and red wires from the motor to each of the outside "poles" of the switch. Wirenut the white wires together and wirenut the green wires together. Don't forget a green lead to your switch box if it's metal. You need to ground that too.
The 6 connector switch is the double pole - double throw. You can use it to switch the neutral (white) connection if you want or leave them unused. If you do leave them unused, just tighten the screws up so they don't vibrate loose on you.
Hi TSurvivor,
The 2 speeds aren't absolutely necessary, but I figured it would be a nice luxury to have as long as I already have a 2 speed motor…
I didn't want to spend more than $15 bucks for a switch, but if I have to to do this safetly I guess I will.
I found this switch that is motor rated, DPDT and has 3 (on-off-on) positions. http://www.drillspot.com/products/440714/Ideal774016Toggle_Switch
Will that work? If so, what about the extra connections in the back? Can I still connect it all as EEngineer suggested?
Sorry if these are extremely elementary questions, but this is all new territory for me.
FYI, Double throw switches do not necessarily have a center off unless the switch functins says they do. Normally a double throw will just be one position or the other.
This is an older thread, you may not receive a response, and could
be reviving an old thread. Please consider creating a new thread.
LumberJocks Woodworking Forum
