1 - 11 of 11 Posts
Hey Jocks,
Here is another question from our of our site users. His name is Dick.
"I need to saw out the floor plate in a cold air return.
Normally, the entire space is cut out for the cold air to flow. However, my contractor only drilled a series of holes and now I need to saw out the wood between the holes. The drywall is installed on both sides so I must reach through the cold ir register.
What type of saw would you suggest?
I was thinking a keyhole saw. Is there a power or air saw that is small enough to get within the 3.5 inch wall and cut out the wood?"
Thanks for your help. :)
Adam
You may have to go the old fashion way, by using a hammer, & chisel.
Discussion Starter · #3 ·
I got some more info from Dick. He also sent some images.
"Attached is a picture of what the plate looks like. I held the camera in the wall cold air return looking down between the wall studs. The space that I have to work in is the 3.5 inches by the 13 inches between the studs. There is not enough space to get a sawsall inside the wall to saw between the holes. Also the ceiling below has drywall so I cannot saw from below. I have also attached a picture of the hole in the wall for the vent.
I appreciate the suggestions. In order to saw the plate, the saw would have to fit between the walls and reach down to the plan which is about 10-12 inches below the opening for the vent"
Thanks for your help!
I don't suppose there's enough room to get a small drill in there and drill a series of holes?
You could use a small powered screw driver wth a drill bit on it maybe.
Good thinking Dennis!!!
I agree, leave it. I'm sure you will get reasonable air-flow through the large holes he's drilled. I very much doubt that he expected anyone to enlarge the opening after the drywall was installed.
Discussion Starter · #11 ·
Here is the final word from Dick on your feedback.
"I wanted to let you know that Frank Chaffee's (from familywoodworking.net) suggestion is probably going to work. He suggested a Fein MultiMaster. I tried one over the weekend and it seems to do the job,
Thanks for all your help and suggestions.
Dick"
Thanks for all your help guys.
Adam
1 - 11 of 11 Posts
