1 - 7 of 7 Posts
Hello again,
I have a project coming up that will require the construction of a new tablesaw sled. The sled I am making can only have one runner, so it has to be a very good fit.
I have tried QS hardwood with marginal luck, but my shop isn't conditioned, so when it goes from 115 in the summer to 40 in the winter, there can be obvious problems with hardwood runners.
I have some 1/4" HDPE that I could make runners out of, but I have heard that the stuff swells when you put screws into the holes that hold the runners on. Obviously, I would predrill them, but I am still concerned about that.
The "adjustable" commerical ones all seem to be flawed in that the adjustments are not continuous along the entire length of the bar, so the bar doesn't stay tight unless you have 2 points of contact with the sides of your TS slots at all times.
All that said, what have y'all had the most luck with when it comes to high performance sled runners?
Thanks
Having a Shopsmith with odd ball sized slots, I am always in need of bars that fit. I'm in AZ so maple does work for me but for those instances where, like you, I want absolute accuracy, I go to a machinist and he mills it for me and gives me countersunk holes for attachment.
My last 4 cost me $68 for all 4. A bit less than what I'd pay from Shopsmith.
I have made them from aluminum bar stock and they worked well but the latest ones I made were from that white plastic/nylon stuff that cutting boards are made from. It can be planed, drilled, sanded and is very stable. A little paste wax and they work super. It may be called HDPE. Several places sell it for facing tablesaw fences but the dollar store cutting boards work fine.
If you have any hard woods: oak, maple, etc, use it, if your slots are 3/4 by 3/8, you can turn a 3/4 board on edge and it should have a greet fit. If it does, while in the slot, draw a line from one end to the other, then set your fence to just take the line off and it will be at the correct depth.
When gluing/attaching the runner, place 4 or 5 dimes equally spaced in the slot to raise above the table. Attach how you prefer and what method will be used to ensure it is square to the blade.
I tablesawed mine a little thicker than I needed and then ran it through the drum sander taking small 'bites' until it was a perfect fit. It will also be OK to run through a planer.
My horseshoer gave me some 3/8×3/4 aluminum bar stock that was nearly a perfect fit for my miter slots. Just hand sanded a couple of tight spots.
1 - 7 of 7 Posts
