Router bit? Are you wanting to cut it or do an edge profile?
Carbide is the way to go as MDF has some hard resin bonding all that sawdust together 8^)
We run a 2 flute 1/2” compression cutter in 3/4” at 750ipm to 800ipm with 20,000 rpm@jaaune what RPM would you run a 2 flute but at?
Thanks for posting this information!!! This is the kind of stuff I like to see on here!!That's a complicated subject since it depends upon the spindle, machine rigidity, material type, hold down strength and various other factors.
Start by looking at the Vortex chipload chart to see what the bit manufacturer recommends. They recommend around 720ipm for a 2-flute, 3/8" diameter bit.
Vortex Chipload Chart
That's the ideal for bit life but not always achievable depending upon the factors mentioned earlier. With our router, we'd probably run about 17,500RPM at 250ipm because the spindle and steppers can't do much better than that which means our machine can't get much benefit from larger diameter, 2-flute bits.
