Not sure how big the base of the saw it, but I just got a Grizzly Bear Crawl base for my G2013 table saw and it's pretty nice. Adjustable size, built really well, retractable castors on one end. They just had a sale on them for under $100
And that is the reason I was wondering if anyone could talk me out of it….Any "genuine" Lumberjock would spend many times the cost of a manufactured mobile base to build "his own."
- Phil32
Does your shop have concrete floors? Expansion joints, or smooth floor?Well, I think that I've found the best solution for my shop that gives me the best mobility with the most stable unit when parked plus it s priced right without being a "cheap" solution, found these at Peachtree, has anyone tried them?
- ChefHDAN
John, I've got a smooth floor but it's not level, I have the Ridgid Herc-u-lift on my other bandsaw, table saw and a sanding station, and the 360 steer has not been a problem, but you've given me something to think about with the small wheel thought. Once these wheels arrive, I'll be looking at them hard to decide whether to mount or return, and go with the all terrain or the bear crawl, which are the top to suggested bases, which both have 2 wheel steer.Does your shop have concrete floors? Expansion joints, or smooth floor?
If you have a smooth floor, then the two casters you have mentioned may be fine.
I unfortunately have expansion joints, and I have tried some bases with smaller wheels, and they suck!
- bigJohninvegas
I had those on 2 tools in years past, one was a Delta drum sander, the second a 6" jointer with open stand. They work, but probably wouldn't be my first choice for a splay legged open stand tool. The legs aren't that stiff and you can get some squirrelly action when rolling the tool around…I suspect on an enclosed stand they would work better keeping in mind the expansion cuts in the floor and the small wheels on the casters. On my jointer I had to add stretchers across the legs to keep them from flexing too much.Well, I think that I ve found the best solution for my shop that gives me the best mobility with the most stable unit when parked plus it s priced right without being a "cheap" solution, found these at Peachtree, has anyone tried them?
- ChefHDAN
Fred, I agree, and was thinking that exactly. The saw has stretchers about 3" up from the floor on the base, until I downloaded the manual I was suspecting that the base was assembled upside down. I'm in the midst of a 6 table job and have a bunch of 1" plywood cutoffs and plan to put a shelf across the bottom to further stiffen the base... wouldn't be my first choice for a splay legged open stand tool. The legs aren't that stiff and you can get some squirrelly action when rolling the tool around…I suspect on an enclosed stand they would work better
- Fred Hargis
