1 - 16 of 16 Posts
I think you need to determine what you'll most likely be doing with the Griz as "general purpose"... If you are going to do any "shaping" you may wish to consider a good 1/4" blade with more teeth (perhaps around 6 tpi)... I also use a 3/16 3 tpi.
At least consider having one to compliment a wider blade so you have it available.
I do a lot of band saw boxes, so I really need the narrower blade.
Consider yourself lucky to have 2 saws!
A Carter Band Saw Stabalizer is a favorite of mine when doing scroll work.
I agree with wncguy, it is nice to have two bandsaws. One set up for re saw work using a 3tpi blade in 3/4" and a second BS with a stabalizer and a 1/4" blade.
"General bandsaw use" can vary greatly in definition from one person to another. Are you planning on doing much tight radius work, do you need a smooth surface finish? A 1/4" to 1/2" blade will fit the bill for most, the tooth count will vary depending on what you'll be cutting. Woodslicer makes great blades in the size you'll likely be looking for.
Premium Member
Discussion Starter · #11 ·
Thank you all for your input. I have a Carter stabilizer that has been knocking around in a drawer for many years. I've tried setting up the Griz with the stabilizer and a 1/4" blade but I'm having trouble getting the stabilizer to align up properly. I'll keep working on it.
Premium Member
Discussion Starter · #13 ·
Unless I ordered it wrong ten years ago it's the correct one. I bought it new a few years after I bought the saw. I get it close but when I tighten down the final thumb screw the bearing tilts jut a bit and the groove and the blade don't align by 1/128th. It's an octagon hole and bar where the saw and the stabilizer connect. The thumb screw locks them together.
Unless I ordered it wrong ten years ago it s the correct one. I bought it new a few years after I bought the saw. I get it close but when I tighten down the final thumb screw the bearing tilts jut a bit and the groove and the blade don t align by 1/128th. It s an octagon hole and bar where the saw and the stabilizer connect. The thumb screw locks them together.
- newwoodbutcher
Carter has some great videos on how to set blade tension and install the stabalizer, if you have not seen them.
And did I tell you how jealous I am? The build and rip capacity really make this BS a very capable machine and reasonably priced. Congratulations!
Premium Member
Discussion Starter · #15 ·
Brad, Yes I've watched their videos and started a conversation with their tec support. Not sure where it's going but in the end I'm sure I will have a great setup. Yes, I am lucky to have two band saws, also a great wife and a great hobby.
With all this input, I'm wondering if I want the stabilizer set up at all. I also have a Hegner scroll saw for scrolling. So I'm thinking a 1/2"and 3/8" set of blades would be the best bet for general purpose curve work. If that's true the stabilizer won't work as they recommend a 1/4" max on that set up. The guides on the old Grizzly are pretty minimal. I Know! This justifies a Carter Guide up grade. So that means this conversation might cost $200.00. Thank you for all your help.
1 - 16 of 16 Posts
