1 - 2 of 2 Posts
That should be easy to re assemble. Do you have a picture of the parts to make sure nothing is missing?
It is just a screw that draws up the upper wheel to put pull the blade tight. Some have a lever to put up the final tension or to release the tension when not in use
I wonder why they would have to foll with the tensioner to move the saw??
..............Jim
1 - 2 of 2 Posts
