"Art Box" Tutorial
465873 Views 460 Replies 244 Participants Last post by  woodisgood
Finishing
The tutorial is under construction.
341 - 360 of 461 Posts
The Handle
Updated 1/15/12
At this point we should have an assembled box, with corner splines, a recess cut into the body for the lid to set down into 3/8", and a recess for the medallion cut into the lid that is also 3/8" deep, and the medallion cut to fit.
DO NOT glue in the medallion yet!
Next thing is to make the handle.
I like to attach the handle by cutting a mortise in both the handle and the edge of the lid and slipping in a thin strip of wood, aka a spline. The spline is a scrap left over from your corner splines.
HOW:
Insert a 1/8'' bit in your table mounted router and cut a slot in the lid and a matching one in the handle blank, about 3/16'' deep. On the handle, stop your mortise about 3/8'' from the ends. Now cut a spline to slip into the slot and make it about 3/8'' shorter than the length of the slot. This will allow you to slide the handle back and forth to position it. If you do much shaping to the handle it may get shorter, maybe on one side more than the other. The wider slot will let you move it back into center of the lid. Ease the edges of your spline with sandpaper to make it easier to slip in and out. Make sure it is narrow enough to let the handle butt up tight to the body.
Here is one ready to mount.
Hand Wood Finger Natural material Tree
Now you can do some shaping prior to mounting it. Just be careful to watch the ends where you can cut into the mortise, and allow for sanding later on after its mounted.
Tip:
If you feel like you are close to exposing the mortise or just want a visual reminder, place a piece of tape on the ends of the handle.
Brown Wood Flooring Floor Wood stain
DO NOT GLUE YOUR HANDLE IN!
We want our handle loose until we are done shaping the seat in the box.
If the handle and its seat dont match up nicely we can always make another if its not glued in.
This picture shows the seat roughed out.
Cut a kerf with a handsaw at each end of the box lip where we marked the seat for our handle. This will prevent the router from tearing out a chunk of wood. You can use a sharp chisel to remove the waste, but I prefer a spiral bit in my table mounted router. Make several shallow passes and clean up the last bit with a chisel and a sanding block. Just get it to where the lid will close all the way. Dont cut all the rim off, leave about 1/8 of the front edge where the handle sits so it will hide the edge of the lid or you will be able to see past and into the box.
Fine sanding can be done later.
You can also do this step with a Dremel or other power tool if you like.
Rectangle Wood Flooring Floor Wood stain
Ready for sanding to fit the handle.
Wood Rectangle Tints and shades Hardwood Magenta
Handle in place after a little more sanding.
Wood Sky Rectangle Tints and shades Hardwood
Now we will cut the pockets for the box to pivot.
On to Chapter 9.
http://lumberjocks.com/Argyllshire/blog/10084
The Handle
Updated 1/15/12
HOW:
Tip:
First off thanks for making the blog, it looks like a ton of work. But of course I have a question, I didn't see what you are using for the pins except for the temporary use of nails. What do you use for a permanent pin? I was thinking brazing rod and a plug?? It's entirely possible that I've just overlooked the info. but I've looked several times.
Thanks
The Handle
Updated 1/15/12
HOW:
Tip:
Thank you Myles.
No, your correct, I didnt specify what I used in the tutorial. Sorry about that !
I have covered the same info on other boxes and fielded that question before, but missed putting it in this blog. Doh!
I did go back and add it to this one just now, thanks for catching that.
I typically use 1/8 brazing rod or get small pieces at the hobby shop that are usually in better condition. I have plugged the ends with dowell but you will not be able to freely round the sides over, you will need to use much more care, and you still see the plug, so I quit doing it that way. Its a personal choice.
I look forward to seeing yours, so drop me a note if you wish, so I dont miss it.
Andy
It all hinges on this.
Updated 1/16/12
This is where you need to decide how you want to open your box.
I mentioned at the outset about some of the different boxes I have made and how they hinge differently from one another. All are good, but you may have a preference in style or it may be your ability that decides for you.
The pin hinge is what we will mainly be focusing on and was used on this box.
Chapter 10 will discuss this style.
Sleeve Wood Bag Beige Khaki
The Deco box uses a standard brass butt hinge with a stop strap. ( The Deco box has a comepletely different type of lid as you can see but was included because it has butt hinges.)
Luggage and bags Bag Sleeve Rectangle Wood
You could also use a butt hinge with built in stops, they cost about $30 a pair.
Or you could use barrel hinges like I did on the Secret box, they run about $16 a pair.
Chapter 11 will cover this style.
Rectangle Wood Bag Hardwood Wood stain
Or you can just make a lift off lid like I used for the Designer boxes.
I am not going to cover this style at this time.
Shoe Wood Luggage and bags Material property Bag
Updated 1/16/12
This series is great!!!
Thanks for all the time you have put in. I can't wait to try some of this.
Updated 1/16/12
Very informitive it looks like the handle is a work of art by itself. good job
Updated 1/16/12
Thank you for all you've put into this! Great boxes and great teaching!
Updated 1/16/12
I am really enjoying your entire series, what a fantastic job!!!
I am knee deep in 4 commisioned boxes now but when I am done, I am going back through all the series and start an "Art box" of my own, with your wonderful inspiration. Thanks again Andy !!!!!
Updated 1/16/12
I am glad this series is making sense.Let me know of any corrections needed.
Thanks for the comments.
Updated 1/16/12
Like reading a good book. Can't put it down.
Updated 1/16/12
Here is where we start the shaping,
http://lumberjocks.com/Argyllshire/blog/10157
Updated 1/16/12
Great tutorial…
Pin Hinges
Updated 1/16/12
I spent a lot of time developing a way to let the lid swing down into the box, yet still maintaining a fairly tight reveal on all four sides
The difficulty is the lip itself. It doesnt allow the back of the lid to drop into the box, so thats where we need to cut it away a little deeper at the back. I call these pockets.
The other difficulty is in getting the hinge placement spot on or it wont open at all or not far enough to stay open.
Here is how its done:
Use the same pattern bit and bearing setup that you just finished using for the lip of the box. What we are going to do is crank the bearing up in several stages to cut deep pockets just at the back for the lid to drop down into.
It will look like this.
Brown Picture frame Rectangle Wood Paint
The finished depth.
Tape measure Office ruler Measuring instrument Rectangle Wood
The finished width.
Ruler Tape measure Wood Office ruler Font
Set a fence 1 1/18'' to 1 3/4'' from the center of the bit.
You will need to experiment with this depending on your bit and bearing setup.
Wood Gas Circle Measuring instrument Auto part
Scientific instrument Office ruler Ruler Camera accessory Drilling
Pin Location:
As the lid drops into the box it scibes a larger arc than it would if we were using barrel hinges or butt hinges.
If we located the pins at the far back corner, then the lid would contact the back lip before it fully opened.
After much experimenting, I came up with a placement that allows the lid to swing down into the box and then lean back enough that it will stay open on its own. Also this location will position the pin in the center of the lid, after we grind away the top portion of the lid.
Remember we have a lid that is 3/4'' thick,and our recess is 1/2'' deep,which leaves 1/4'' of the lid standing out of the box.S o, if we shape the top of the lid down to the lip of the box we will end up with a lid that is only 1/2'' thick at its edges, which places the pin in the center of the edge.
Brown Handwriting Rectangle Wood Signature
Drill the hole the diameter of your brass pins. I use 1/8" brazing rod found at most hardware or welding supply stores.
Drill about 1 1/2" deep total. I am using a simple jig with steel bushings, one leg is for the left and the jig swings around to do the right. Tou can eyeball it with a hand drill or use a drill press. If the pins are not in alignment the lid will swing up crookedly and bind up.
Handheld power drill Wood Table Rotary tool Rectangle
The lid will be off and on several times while you remove the wood on both the lid and box at the back. I use long roofing nails to act as temporary hinges, they are easier to get out. Polish them up so the slip in smoothly.
Brown Picture frame Blue Rectangle Wood
Before we can open the lid we need to pare away some wood on the top and bottom, at the very back edge.
Paint Wood Grey Rectangle Art
Tip:
Wiggle the lid up and down when you have the pins in,even if its a little bit,remove the pins and look for rub marks where its tight and sand those away. Keep doing this.
Warning: I want to caution you about going too fast because it is very easy to remove too much wood at the back, leaving a thin line that will disappear if you grind into it. Final sanding will remove additional wood, aggravating the problem even more. If you arent sure how much wood you have left along the back edge, then just stay away from there when shaping.
This photo
shows a side view of the lid after beveling the top/back edge and bottom/back edge and corners. Final fine sanding will be done later.
Here you can see the line where we stopped the top bevel, and if you look to the far right, in the middle, you can see a flat spot about 1/4'' high.That is the only area that is still in contact with the back of the box. Carefully hand sand along this line until the lid opens without rubbing. Do this at a downward taper.
Keep in mind that your finish will add little material to each surface and you may get areas where it will rub.This is one of those things that depends on many factors including humidity. Just be sure it works pretty good for now and you can fine fit it later just before finishing.
Wood Rectangle Tints and shades Magenta Electric blue
And here we have a working lid.
Rectangle Wood Wood stain Hardwood Bag
Pin Hinges
Updated 1/16/12
The finished depth.
The finished width.
Pin Location:
Tip:
This photo
Super blog interesting work thanks for sharing
Pin Hinges
Updated 1/16/12
The finished depth.
The finished width.
Pin Location:
Tip:
This photo
i guess it is only wood
Pin Hinges
Updated 1/16/12
The finished depth.
The finished width.
Pin Location:
Tip:
This photo
giving the design character and personality…nice work.
Pin Hinges
Updated 1/16/12
The finished depth.
The finished width.
Pin Location:
Tip:
This photo
I have wood for several boxes cut. I was thinking my first would have a lift off top like your designer boxes then move on to more complicated. I get the idea that the lid fits snugly to begin with but does it really stay in place when you take the angle grinder to it? I was thinking it might need something like double sided tape.
Also I had some 1/8 walnut for the splines and I used a single dado blade (with a flat grind) from my stack to cut the slots and it came out a little slopy by about 64th or so. I have my fingers crossed. Back to the drawing board.
Jonathan
Pin Hinges
Updated 1/16/12
The finished depth.
The finished width.
Pin Location:
Tip:
This photo
Please don't stop this blog as I have it all printed out so I can make a box when the instructions are complete.
Pin Hinges
Updated 1/16/12
The finished depth.
The finished width.
Pin Location:
Tip:
This photo
Thanks for reading everyone.I am working on the next installment and will post soon I hope.I have a lot going on this summer :)
@Jonathan-You are right…tape is a great way to hold the lid in place while shaping.
Pin Hinges
Updated 1/16/12
The finished depth.
The finished width.
Pin Location:
Tip:
This photo
And onto the next
http://lumberjocks.com/Argyllshire/blog/10308
