"Art Box" Tutorial
465599 Views 460 Replies 244 Participants Last post by  woodisgood
Finishing
The tutorial is under construction.
321 - 340 of 461 Posts
14
The Medallion
Updated 1/15/12
Now we need to cut a recess in the lid for the medallion to set down into.
DONT cut your medallion until you have routed out the home for it.
I typically make the medallion about 1" to 1.5" smaller on all sides than the lid depending on the box size and the piece of wood I have for the medallion.
Rectangle Wood Font Wood stain Musical instrument
We are now going to make a simple jig for a router to set on and run back and forth making several passes of incrementally deeper cuts. There are a several ways to do this next step and it will depend on the router bit you use and the thickness of the material you have to make your template.
Here is how I made this one:
#1-The photo below shows two layers of strips of 1/2" melamine butted tight to the lid. This will hold the lid in place and make a flat base for the next layer of strips. I used scraps about 3'' wide, running one end past the other, all the way around the lid.
Wood Rectangle Floor Flooring Wood stain
#2- Next I mounted a block of wood the exact size of the medallion, centered in the top of the lid in the exact spot I want the recess to be.
You can use double stick tape, but I prefer screws so it cant get bumped out of place. The holes go away with the milling.
Now add the last layer of strips, rotating the joints so they are offset with the ones below. Butt this layer up to the center block, making sure its snug, but remember you will need to be able to remove the block.
Wood Gas Composite material Plywood Rectangle
The height will depend on the pattern bit you use. My bit was 1 1/4" PLUS THE BEARING so I ended up with a template stack of 1 1/2". ( 3 layers of 1/2" melamine )
Thats on the extreme edge of reach for most routers to travel, so If you are buying a bit for this project just get a shorter one and make your jig accordingly.
Wood Table Wood stain Hardwood Varnish
Tip:
Make it smooth on the inside or you will get bumpy sides. You need to allow the bit to ride on a perfectly smooth face down the sides of your jig, for about 3/8'' of travel. I always do a practice run on a scrap just to be sure the quality of the cut is smooth.
Its a good idea to remove most of the material in the center using a forstner bit, that way the router bit is only cutting one edge instead of two. If you just plunge into the center of a hardwood like bubinga the bit will chatter because it is trying to cut on all its edges at the same time. Thats not so bad as long as you stay away from the edges, but it can break a 1/4 shank bit. Its hard to believe but this chattering and even chips bouncing around can cause small uneven cuts along the edge that will show up. The only way to fix it is to reposition the jig and recut the recess.
The best way to prevent this from happening is to:
Work from the center out
Work at a slow and even pace
Keep the chips cleared as you get closer to the sides
Wet the edges with a damp rag
Make multiple passes
Wood Gas Machine Composite material Plywood
And here is how the test block fits into the recess.
Wood Rectangle Tints and shades Wood stain Gas
This photo shows the lid nestled into the rim of the box and the medallion setting in its recess. The medallion doesnt need to be this thick, it can be flush with the lid. It all depends on how you want to shape the top. Sometimes I will split a 3/4 board in two pieces and use it for two medallions and just shape a gentle dome on the top.
Wood Rectangle Handwriting Material property Font
The handle comes next.
Andy, this is good stuff. I wish I were in a position to build as you teach, but scheduling is not allowing that. We won't mention that my skills might also get in the way. But I've marked each entry for future reference and will be putting this information to work as soon as I can. Thanks for all the detail.
The Medallion
Updated 1/15/12
Tip:
Andy…I just finished printing off your tutorials. I think you have good presentation skills. Love your work and thanks for sharing your expertise. I don't know who said it, but, "a candle looses nothing if it lights another candle" Hope you'll do more.
The Medallion
Updated 1/15/12
Tip:
I am glad that this series is making sense.I dont have any formal training,so I am trying to write this in the way I would want to read it.
Thanks to all of you for reading this series and taking time to make positive comments.
I am working on the next chapter,but it will be a few days before I will have it ready to post.
The Medallion
Updated 1/15/12
Tip:
The link will take you to the helpful hints page.
http://lumberjocks.com/Argyllshire/blog/9943#comments
The Medallion
Updated 1/15/12
Tip:
Great job and keep the tutorials coming.
I need to complete my box.
Thanks for sharing
The Medallion
Updated 1/15/12
Tip:
Here is the next chapter.
http://lumberjocks.com/Argyllshire/blog/10058
The Medallion
Updated 1/15/12
Tip:
Andy
If you dont rout the lip,where do you place the hinge pins so the top will open.This looks a lot easier as I just made the same mistake you did on your demo box.Thankfully,this was my pine practice box!I want to inset the lid like yours,but wil use stop inside box rather than route the lip.Thanks for the great tutorial.You are my woodworking role model.
gfadvm
The Medallion
Updated 1/15/12
Tip:
gfadvm- If you dont route the top, which will allow the lid to set into a recess, then the pins wont work for hinges. You will need to use the barrel hinges or some sort of butterfly style.
Thanks for the compliment, and I look forward to seeing what you come up with, send me a note when you post it.
Andy
The Medallion
Updated 1/15/12
Tip:
Andy, your craftsmanship is very inspiring to me. Thank you for everything you have put into this blog.
I have a question for you regarding the barrel hinges. If the bottom hinge holes are even slightly out of alignment with the hinge holes in the lid, it will be bad news. Measuring and marking the locations seems a little suspect. Do you have a technique for reliably matching the hole locations prior to drilling?
I have these little buttons with "spikey" tops that came with a doweling jig, and I've thought about inserting those in the lower holes then carefully pressing the lid into position, thus indenting the under-side of the lid, but I thought you might have developed a better way.
Hug those grandbabies.
The Medallion
Updated 1/15/12
Tip:
Mark, thats a good point and the pins would work well for alignment.
I simply set the lid into its recess on the box and mark both hinge locations on the back and transfer the lines onto the mating surfaces. You must be careful, but its not very difficult to get it right.
Have fun,
Andy
The Medallion
Updated 1/15/12
Tip:
my turn
The Medallion
Updated 1/15/12
Tip:
Andy, reading and learning from your great tutorials. I'm a little perplexed by the fact that the top(3rd) layer of strips don't seem to be flush/level where they meet at the corners. being that the router bears on these how do you get a flat bottom?
The Medallion
Updated 1/15/12
Tip:
You're right Pat. The picture doesn't show how I leveled up the template with strips of heavy paper prior to using it. But, I found that as long as the bottom is somewhat flat after routing, I can just level it up a little better with a chisel. And a good coat of glue will hold it fine, plus you will never see the joint if it has small gaps.
The Medallion
Updated 1/15/12
Tip:
Thanks, I use playing cards as shims all the time. I guess there is no real stress on the medallion so if its not glued at 100 % its not that big a deal.
I get that the carving process is something that is personal and each person will have a different technique, any other pointers then what you have in the tutorial would be much appreciated.
The Handle
Updated 1/15/12
At this point we should have an assembled box, with corner splines, a recess cut into the body for the lid to set down into 3/8", and a recess for the medallion cut into the lid that is also 3/8" deep, and the medallion cut to fit.
DO NOT glue in the medallion yet!
Next thing is to make the handle.
I like to attach the handle by cutting a mortise in both the handle and the edge of the lid and slipping in a thin strip of wood, aka a spline. The spline is a scrap left over from your corner splines.
HOW:
Insert a 1/8'' bit in your table mounted router and cut a slot in the lid and a matching one in the handle blank, about 3/16'' deep. On the handle, stop your mortise about 3/8'' from the ends. Now cut a spline to slip into the slot and make it about 3/8'' shorter than the length of the slot. This will allow you to slide the handle back and forth to position it. If you do much shaping to the handle it may get shorter, maybe on one side more than the other. The wider slot will let you move it back into center of the lid. Ease the edges of your spline with sandpaper to make it easier to slip in and out. Make sure it is narrow enough to let the handle butt up tight to the body.
Here is one ready to mount.
Hand Wood Finger Natural material Tree
Now you can do some shaping prior to mounting it. Just be careful to watch the ends where you can cut into the mortise, and allow for sanding later on after its mounted.
Tip:
If you feel like you are close to exposing the mortise or just want a visual reminder, place a piece of tape on the ends of the handle.
Brown Wood Flooring Floor Wood stain
DO NOT GLUE YOUR HANDLE IN!
We want our handle loose until we are done shaping the seat in the box.
If the handle and its seat dont match up nicely we can always make another if its not glued in.
This picture shows the seat roughed out.
Cut a kerf with a handsaw at each end of the box lip where we marked the seat for our handle. This will prevent the router from tearing out a chunk of wood. You can use a sharp chisel to remove the waste, but I prefer a spiral bit in my table mounted router. Make several shallow passes and clean up the last bit with a chisel and a sanding block. Just get it to where the lid will close all the way. Dont cut all the rim off, leave about 1/8 of the front edge where the handle sits so it will hide the edge of the lid or you will be able to see past and into the box.
Fine sanding can be done later.
You can also do this step with a Dremel or other power tool if you like.
Rectangle Wood Flooring Floor Wood stain
Ready for sanding to fit the handle.
Wood Rectangle Tints and shades Hardwood Magenta
Handle in place after a little more sanding.
Wood Sky Rectangle Tints and shades Hardwood
Now we will cut the pockets for the box to pivot.
The Handle
Updated 1/15/12
HOW:
Tip:
very well presented … I'm glad I marked you as a buddy … I've learned allot from reading your blogs
thanks for sharing
The Handle
Updated 1/15/12
HOW:
Tip:
Andy…I just wanted to say "Thank you" for all the work you have put into this tutorial. You have done an excellant job that I know it has taken you a lot of time and effort. Thanks again for sharing you talent and knowledge.
The Handle
Updated 1/15/12
HOW:
Tip:
Hey Andy… I really enjoy your blog. Thanks for taking the time to write it up.
The Handle
Updated 1/15/12
HOW:
Tip:
You are very welcome! Its alot of work,but I enjoy doing it.I hope it is clear and someone can use this info to make a box.I am learning from doing this too.I also anticipate picking up some tricks from some of you.
Thanks again.
The Handle
Updated 1/15/12
HOW:
Tip:
Hi Andy;
You sure did a good job on this series!
Very, very well done!
