"Art Box" Tutorial
465816 Views 460 Replies 244 Participants Last post by  woodisgood
Finishing
The tutorial is under construction.
301 - 320 of 461 Posts
The Lid
Updated 1/15/12
Regarding wood movement:
Depending on the wood you use, where you live, and your own personal experience,y ou may want to allow more clearance.
This is what works for me.
I really dont allow for any movement at this stage. I know this sounds like trouble waiting to happen, but it works just fine for me. Even if we start off with a snug fit, we will still end up with a small gap around the perimeter. This is due to the final sanding and easing of the edges between lid and lip. Feel free to start off with a small gap (1/16) or so if you wish. But keep in mind that as you sand your mating edges, that its very easy to get a sloppy fit. This would allow the lid to move from side to side, which will just feel wrong, and the pins may show too much in the gap, and the handle may not drop straight into the seat, and the sides may rub on the way down.
Cutting the lid to size is nothing more than cutting a rectangle exactly the size of the opening and then radiusing the corners.
Here is the lid blank cut to size and prior to rounding the corners…obviously.
Wood Rectangle Hardwood Wood stain Drawer
I choose to sand the corners to match the profile of the box using a template to first mark out the radius.
I bought a set of cool templates at Woodcraft.
Writing implement Pen Office supplies Handwriting Wood
Then its over to the disc sander to get close but leaving enough to fiddle with by hand.
Wood Stairs Rectangle Table Wood stain
OR you can make a template for the entire top out of ply or masonite or…well you get the picture. With a template you can stick it to your lid and run it around a router with a template bit. It may want to eat a corner or two, thats why I prefer to sand to fit. Just go slowly. Turn down the Rap music and pay attention at this point anyway.
Rectangle Wood Ingredient Cuisine Tints and shades
The lid all snug in its new home.
Brown Handwriting Rectangle Wood Font
Andy, this is a great tutorial series. Thanks a lot for sharing.
The Lid
Updated 1/15/12
Super presentation! You're making it look awful easy…If I ever come across some suitable woods, I'm going to have to attempt this. :)
Darn nice of you to take the time to document and photograph your process of creation, many thanks!!
The Lid
Updated 1/15/12
Thank you all for reading this and commenting.
Here is chapter 7.
http://lumberjocks.com/Argyllshire/blog/9871
The Lid
Updated 1/15/12
Andy;
I really want to take a shot at making at least one of these boxes, but I'm not sure I understand the procedure for cutting the medallion once the lid inset is cut. You wrote that the medallion is cut the same way as the lid, but to me that procedure only works for a recess. If we use the same process used to cut the recess in the lid then wouldn't the medallion be too small on all sides by 3/4" (2 x's the diameter of the router bit)?
Any help for the confused is appreciated.
Thanks,
TJ
The Lid
Updated 1/15/12
Hi TJ, l think I see your problem. Lets look back at the photos, I think they explain the process best. Make a jig as shown that leaves a border around the medallion about 1 1/4'' or so,and cut a recess about 3/8'' deep using a pattern bit with a bearing that is the same diameter as the bit.
The medallion is cut to size after that to ensure a good fit.
It can be very confusing when laying out templates and bits with different sized bearings.There are other ways to accomplish this same thing,including using template guides,but this is what I had on hand. I do recommend practicing on a dummy box first.
Let me know if this doesnt answer your question, I want you to be able to do this too.
The Lid
Updated 1/15/12
Eureka…the light just came on. Doh!
Thanks, I think I've got it now.
The Lid
Updated 1/15/12
love it
The Lid
Updated 1/15/12
Andy,
I really appreciate you taking the time to post such a great blog on how you do your boxes. This is one of those "DOH" projects where once you do it, you realize the techniques are really quite simple and make sense.
I made a run of 3 of these boxes out of Claro Walnut with quilted maple inserts to give out as gifts. I wasn't really happy with how my sculpting/carving of the boxes came out (they didn't really flow organically the way I would have liked - but the recipients all loved them) but have some good ideas on what I want to do next time I get down to doing these.
Thanks again for your contributions around here.
The Lid
Updated 1/15/12
Andy:
Great tutorial and I am just now starting. Had to re read procedures but I am doing as you say by trying on a practice box first
Wonderful pictures and once I have re read it twice I finally get it
again another light is lit.
TNX again.
PS: I am working on palm boxes too.
Bruce
re tired and tired too.
The Lid
Updated 1/15/12
Andy,
Revisiting this fantastic tutorial. I am attempting making one of these boxes and have partially made the dummy box.
I don't have a single large enough board to make the lid out of. My idea is edge join two pieces of alder, then continue on as outlined here on your tutorial.
Do you think I will have problems later when I add the medallion and start the shaping?
The Medallion
Updated 1/15/12
Now we need to cut a recess in the lid for the medallion to set down into.
DONT cut your medallion until you have routed out the home for it.
I typically make the medallion about 1" to 1.5" smaller on all sides than the lid depending on the box size and the piece of wood I have for the medallion.
Rectangle Wood Font Wood stain Musical instrument
We are now going to make a simple jig for a router to set on and run back and forth making several passes of incrementally deeper cuts. There are a several ways to do this next step and it will depend on the router bit you use and the thickness of the material you have to make your template.
Here is how I made this one:
#1-The photo below shows two layers of strips of 1/2" melamine butted tight to the lid. This will hold the lid in place and make a flat base for the next layer of strips. I used scraps about 3'' wide, running one end past the other, all the way around the lid.
Wood Rectangle Floor Flooring Wood stain
#2- Next I mounted a block of wood the exact size of the medallion, centered in the top of the lid in the exact spot I want the recess to be.
You can use double stick tape, but I prefer screws so it cant get bumped out of place. The holes go away with the milling.
Now add the last layer of strips, rotating the joints so they are offset with the ones below. Butt this layer up to the center block, making sure its snug, but remember you will need to be able to remove the block.
Wood Gas Composite material Plywood Rectangle
The height will depend on the pattern bit you use. My bit was 1 1/4" PLUS THE BEARING so I ended up with a template stack of 1 1/2". ( 3 layers of 1/2" melamine )
Thats on the extreme edge of reach for most routers to travel, so If you are buying a bit for this project just get a shorter one and make your jig accordingly.
Wood Table Wood stain Hardwood Varnish
Tip:
Make it smooth on the inside or you will get bumpy sides. You need to allow the bit to ride on a perfectly smooth face down the sides of your jig, for about 3/8'' of travel. I always do a practice run on a scrap just to be sure the quality of the cut is smooth.
Its a good idea to remove most of the material in the center using a forstner bit, that way the router bit is only cutting one edge instead of two. If you just plunge into the center of a hardwood like bubinga the bit will chatter because it is trying to cut on all its edges at the same time. Thats not so bad as long as you stay away from the edges, but it can break a 1/4 shank bit. Its hard to believe but this chattering and even chips bouncing around can cause small uneven cuts along the edge that will show up. The only way to fix it is to reposition the jig and recut the recess.
The best way to prevent this from happening is to:
Work from the center out
Work at a slow and even pace
Keep the chips cleared as you get closer to the sides
Wet the edges with a damp rag
Make multiple passes
Wood Gas Machine Composite material Plywood
And here is how the test block fits into the recess.
Wood Rectangle Tints and shades Wood stain Gas
This photo shows the lid nestled into the rim of the box and the medallion setting in its recess. The medallion doesnt need to be this thick, it can be flush with the lid. It all depends on how you want to shape the top. Sometimes I will split a 3/4 board in two pieces and use it for two medallions and just shape a gentle dome on the top.
Wood Rectangle Handwriting Material property Font
The handle comes next.
The Medallion
Updated 1/15/12
Tip:
Andy, good tutorial. Great looking boxes. Nice selection of wood. Kudos.
The Medallion
Updated 1/15/12
Tip:
I've been following along and this is wonderful Andy…........... you are doing a great job and providing great instructions and tips. Keep it up and thanks again.
The Medallion
Updated 1/15/12
Tip:
Super! Super good job! Ok when are you going to start your video series on PBS? ; ) Really, I do thank you for this blog, it's great!
The Medallion
Updated 1/15/12
Tip:
Boy…...thank you all for the support:)
I know I am probably giving way too many details for most of you,so I thank you for your patience.
My goal is to encourage everyone regardless of ability, to try their hand at this project.
Hopefully,my thoroughness will prevent you from making many of the same mistakes I have made.
And I am looking forward to seeing what you will come up with.I hope to learn better ways to make these boxes,to learn from your experience.
Dont hesitate to let me know of any errors in my write up,or questions you need answered.
Please do that right here in the comments section.That will minimize duplication of the same concerns,and also,everyone can read the answer.
The Medallion
Updated 1/15/12
Tip:
great tutorial! Thanks for takeing the time to write it. Well Done! Hope you will do more tutorials you are very good at explianing your work and with pics it really helps to see what your talking about.
The Medallion
Updated 1/15/12
Tip:
Andy, this is an excellent tutorial series. You have explained it well and documented the process thoroughly. You certainly have made it clear for me.
The Medallion
Updated 1/15/12
Tip:
I've been following along with a deep appreciation of your dedication to sharing this with us. It's a lot of work and a labor of love indeed. Thanks - I'll remain a loyal reader!
The Medallion
Updated 1/15/12
Tip:
I just found this tutorial and picked out a piece of mahogany and a piece of poplar to start with! I've made a lot of boxes from books and magizines but this is one of the most interesting boxes I've seen.
Thanks!
The Medallion
Updated 1/15/12
Tip:
Hey Andy
This is spectaular totorial well done.
