1 - 18 of 18 Posts
· Registered
Discussion Starter · #1 ·
Adding Corner Splines To A Box With Frontal Drawers
I've had some members inquire on how I add splines to my box drawers so I thought I'd put together a how-to on how I do it.
Your project might differ than mine but this will give you the how to along with the concept. My boxes consist of split drawers that require three cuts yours may consist of a single drawer that runs the length of the bottom of the box in which would require only a single cut the length of the box.
I'll try and explain as best as I can on the pictures below if you have any questions please feel free to ask.
Wood Table Rectangle Plank Hardwood
Get all of your walls cut along with miters and pull the front wall aside.
Wood Rectangle Natural material Wood stain Hardwood
Showing where the miters have been cut.
Rectangle Wood Table Material property Plank
Measure the size of your drawer front and mark your cut line on the face of the front wall. You can use a tablesaw if you're only making a single cut the length of the box but a bandsaw is better as it doesn't remove as much material as a tablesaw blade.
Table Wood Rectangle Flooring Floor
Wood Table Flooring Floor Wood stain
Wood Flooring Rectangle Floor Table
Wood Road surface Flooring Floor Asphalt
Wood Table saws Floor Flooring Composite material
Rectangle Wood Flooring Table Wood stain
Showing after pieces cut.
Bumper Wood Automotive exterior Gas Composite material
Sanding the blade marks.
Wood Floor Hardwood Flooring Tool
Showing how they lay out.
Wood Floor Tool Flooring Rectangle
Wood Rectangle Flooring Wood stain Composite material
I like to allow 5 mins for the end grain to soak up the glue then apply a second application of glue.
Wood Rectangle Flooring Wood stain Hardwood
After everything has dried, what it looks like, once again your box will look different as you won't have an inner core box on the inside.
Wood Gas Tool Satellite phone Machine
Shoe Wood Floor Flooring Wood stain
It's now time to glue your drawer fronts to your constructed drawers, I use 1/8" spacers set inside of the drawer cavity that lay on the back wall to set the drawers to stick up just enough so that the drawer fronts meet the drawer to be glued too and then tape and clamp.
Wood Wood stain Flooring Rectangle Plank
Showing after the drawer fronts have been glued to the drawers.
Brown Rectangle Wood Table Flooring
Brown Rectangle Wood Beige Road surface
Tape the drawers in place to the box and mark your spline cuts take care not to cut a spline where the drawer meets the box.
Brown Rectangle Wood Grey Flooring
Showing where the drawer front meets the box, don't cut a spline in this area.
Rectangle Wood Flooring Floor Table
After splines have been cut.
Wood Wood stain Floor Flooring Hardwood
Separate the drawers from the box.
Wood Wood stain Plank Flooring Hardwood
Glue splines in place.
Wood Flooring Floor Hardwood Rectangle
Once they've dried remove access on bandsaw.
Wood Flooring Rectangle Floor Wood stain
Wood Flooring Floor Wood stain Beam
Wood Floor Flooring Hardwood Plank
Shipping box Wood Floor Gas Hardwood
Wood Gas Machine Metal Engineering
Use a dremel tool with a #60 sanding drum to remove the spline that you're not able to reach with a blade.
Wood Gas Tints and shades Hardwood Flooring
After you've sandier the access away.
Wood Office ruler Wood stain Hardwood Plank
The final outcome.
· Registered
The final outcome.
Randy,
The band saw box is the core of your work. I get to see it here. Pictures 25 and 26? No comment there. Is it a jig for the band saw?
Happy New Year my friend.
· Registered
Discussion Starter · #3 ·
The final outcome.
No bandsaw jigs Tom, just the tablesaw jig for cutting the splines. I'm just real careful not to allow the blade to nick the walls.
Thanks and Happy New Year.
· Registered
The final outcome.
What a neat way to do things…and the end products are awesome, Randy. Thanks so much for taking the time to post and explain! Happy New Year, bud!
· Registered
The final outcome.
What a great tutorial, thanks for sharing, your end product is definitely a wonderful work of art. Happy new year.
· Registered
Discussion Starter · #6 ·
The final outcome.
Thanks everyone glad I could help. Please don't hesitate if any questions.
This box will be posted soon as a project, the wood used on this box was Spalted Texas Cedar Elm.
· Registered
The final outcome.
i made a tablesaw sled with a removeable jig to put your boxes in to cut slots for splines, it works great and is easy to use, here is a picture if anyone wants to look at it
Wood Flooring Floor Rectangle Wood stain
· Registered
Discussion Starter · #8 ·
The final outcome.
That's a nice one Grizz, mine is a bit different, it rides the fence and small enough to hang on the wall.
· Registered
The final outcome.
Excellent writeup!
· Registered
The final outcome.
hey Randy, i hang mine at the end of my workbench, which is just behind me and over to the left, its very handy, and when I don't need the slot jig it comes off with just a few screws, another tool that is very handy to make slots is the biscuit slot cutter, its very versatile and works really well, because of its size it does really well if you have some strange areas that might be a challenge to get to.
· Registered
The final outcome.
Happy New Year ! LOL!
· Registered
The final outcome.
Another gr8 way to do splines. Thnx for the pictorial Randy.
· Registered
Discussion Starter · #13 ·
The final outcome.
I never thought about using my biscuit slot cutter.
