1 - 17 of 17 Posts
Premium Member
Discussion Starter · #1 ·
Start up, top first
OK, there is a brand new Gazebo sitting on the back patio…has a few chairs. Would be nice to have a table to sit in-between the 2 rocking chairs….and set my cold drink on this summer…maybe a plate of snacks? I still have about 15 bft of Ash lumber…..Maybe build a table out of that? So…
Have three 1×6 x 4' planks….hauled those to the shop. Weight restrictions meant one at a time..
Wood Composite material Track Bumper Building material
With the worst of these three on top. there are still three planks upstairs…1×6 x 75"..don't think I'll run out soon..
Checked the ends of the top plank….hopefully to get about 30" or so of decent lumber…
Hood Sleeve Wood Automotive tire Flooring
Glance along an edge…not too great…ends ?
Wood Rectangle Wood stain Floor Flooring
Well, this end will need trimmed a bit…other end?
Wood Automotive tire Hardwood Plank Lumber
That knot has got to go…set up a "saw bench"
Wood Table Rectangle Composite material Outdoor bench
D-112 saw to make a few cuts…
Wood Track Composite material Railway Engineering
Split the line…and see how it turns out..
Hand tool Metalworking hand tool Tool Wood Saw
Used this first plank, to lay out #2….trying for the best section in there..
Wood Water Automotive tire Building Building material
One end didn't need too much off…
Rectangle Wood Flooring Floor Road surface
Saw was shiny enough…I could see a reflection..
Automotive tire Wood Automotive wheel system Auto part Bumper
Same with plank #3…then laid all three on the bench…
Table Wood Floor Flooring Hardwood
Hmmm, might be a little while, before the clamps and glue can arrive….
Tablesaw to rip down the worst of the curvy edges…try again..
Wood Rectangle Table Flooring Floor
Still going to arrange for best match….need to run the Jointer Plane to straighten things out a bit…..
Weight restrictions end this weekend…..may get the Stanley No.6c to work on that.
Plan right now? get this top glued up, and set aside. Then craft a set of legs…by gluing 2 strips up, to make a square stock. Once those are done….Details, details, details…..rumour is a drawer will be involved…with 5-1/2" wide aprons…..we'll see
Stay tuned…
Start up, top first
Stay tuned…
Looking good, curious, do you clamp the 2 boards together and joint them or do 1 at a time?
Premium Member
Discussion Starter · #3 ·
Start up, top first
Stay tuned…
I do one at a time, usually…
Wood Textile Wall Tool Hardwood
Premium Member
Discussion Starter · #4 ·
Glue up the top
Need to joint the edges, first..
Hand tool Wood Metalworking hand tool Automotive tire Automotive exterior
Had a choice between Jointer planes….settled on the smaller Millers Falls No.15…..instead of the heavier Stanley No.7c…...
Wood Plank Hardwood Composite material Lumber
Watching how the grain is running….first edge done. Get a couple more edges done. I can use one edge to check another…
Wood Rolling Automotive exterior Table Hardwood
Top one has a slight bow to it….might be able to caul that out?
Wood Table Rectangle Floor Flooring
Kept laying the boards out, trying for best grain matches..
Wood Wood stain Flooring Hardwood Plank
Even used line up marks….
Wood Hardwood Flooring Gas Plank
Finally, glue, cauls , and clamps…
Saw Automotive tire Wood Drill Gas
Cauls were doubled up…..
Wood Art Lumber Hardwood Machine
Let this sit a day, or so…..then, today, most of the clamps came off…
Wood Beige Rolling Luggage and bags Gas
Made it easier to set the panel aside…..needed the tablesaw…had leg blanks to rip for width..
Wood Automotive exterior Composite material Roof Motor vehicle
Had to use the handsaw…to cut the blanks for length..
Wood Lumber Flooring Hardwood Machine
Then glue 4 pairs into leg stock…
Wood Outdoor furniture Outdoor table Picnic table Outdoor bench
Trying to watch the grain, a bit…
Wood Building Urban design House Landscape
Will let these sit a day….then clean up the edges. Plan is to taper 2 sides….letting the best 2 show. After that?
Stay tuned…
Glue up the top
Stay tuned…
Now that's a few clamps ;D
Premium Member
Discussion Starter · #6 ·
Taper the legs?
Legs came out of the clamps. Reset the rip fence, and ran each leg through. Goal being to have a square blank..
Wood Lumber Plank Hardwood Building material
Glue lines needed taken down a bit. Aprons will be at 5" width….so, the taper will start below that. Trying to neck things down to a 3/4" x 3/4" square foot…have a 3' steel ruler, to do the lay out with.
Wood Composite material Building material Metal Hardwood
Trying to remove the worst of the sides, and leave a nice grained side…bandsaw has a brand new, 1/4" blade in it…maybe it won't burn quite as bad….
Wood Composite material Track Metal Plank
Two legs done. Which leaves…
Wood Wood stain Plank Flooring Hardwood
These 2 blanks…..was getting a bit late, last night….decided to finish up today..
Table Wood Rectangle Wood stain Floor
Didn't take all that long to cut on the bandsaw….except I needed to plane all the saw marks off, and get rid of all the wavy edges….we have ways..
Motor vehicle Wood Automotive tire Bumper Tool
Millers Falls No. 15, and the Millers Falls No. 9. You can also see the 36" Tinner's ruler. Made a mess..
Table Wood Motor vehicle Gas Hardwood
Will see about starting on aprons, tomorrow…..
Stay tuned…
Premium Member
Discussion Starter · #7 ·
Aprons?
No, not one of these..
Cabinetry Sleeve Collar Motor vehicle Drawer
More like the wooden ones, that connect 4 legs to a table….Hauled the rest of the lumber to the shop…made a few cross cuts…
Wood Hardwood Plank Lumber Wood stain
Was still a bit left over..
Wood Motor vehicle Track Gas Lumber
Then set the rip fence to rip one straight edge….reset and rip the other edge to match….then set up a "Set up Block"
Wood Composite material Metal Roof Engineering
Reset the fence, and the blade height…..and mill a few tenons…
Wood Hardwood Building material Plank Lumber
3 out of 4….#4 involves a drawer front..
Wood Rectangle Flooring Hardwood Natural material
Will cut those tenons later….along with the drawer to final width…had to clean up the tenons a bit..
Wood Gas Machine Metal Auto part
They were a bit rough. Set up the Stanley #45 with a bead cutter…figured a way to hold the 4 legs steady enough to mill a double bead on the outside corners..
Wood Eyewear Vision care Art Font
Got the 4 legs done…and started on a bead detail along the bottom edge of the aprons..
Wood Roof Composite material Metal Machine
Which needed face planed smooth, first…before the beads were made…
Motor vehicle Wood Automotive tire Automotive wheel system Auto part
Just a simple, single bead along the bottom edge..
The piece the drawer will ride on…also gets a bead….
Wood Outdoor bench Table Hardwood Brick
Beads at the top? won't be seen, why bother…..
The "T" marks on the top of the legs?
Wood Eyewear Font Tints and shades Automotive exterior
Mark where the taper is….and where the mortise for the tenons will go….don't want to chop the wrong hole…
Laundry Detail later today…....means I might get a little shop time in…...sit around waiting on the washing, while chopping a few mortises….
Stay tuned
Premium Member
Aprons?
Stay tuned
Looking good Bandit!
Premium Member
Discussion Starter · #9 ·
Mortises, two ways
Well, I was going to do Olde School and chisel/chop them out..
Wood Art Rectangle Font Brick
Was taking way too long…Thought there MIGHT be a quicker way….Seems the tenons are 3/8" thick….hmmm
Automotive tire Wood Motor vehicle Wheel Gas
I do have a decently sharp 3/8" Forstner bit….I'd still have to lay out the mortises the same way….then clean the mortise out with a chisel..
Wood Gas Metal Roof Lumber
Seemed to go a little quicker…..like about 3 this way, to 1 the other way….able to get a few dry fits, too…
Wood Hardwood Rectangle Wood stain Plywood
Even to the point that clamps (no glue..) got involved..
Wood Gas Composite material Lumber Metal
Needed to size the drawer front….along with it's 4 tenons..
Wood Rectangle Composite material Gas Hardwood
Need to drill/chop out the matching mortises…next time in the shop….
hauled a 1×6 x 8' pine plank to the shop…..needed 2 slabs for the sides of the drawer..
Wood Automotive tire Asphalt Bumper Road surface
D-112 to make a few cuts….along with the back of the drawer..
Wood Automotive exterior Bumper Tool Auto part
Reset the rip fence…need to rip the 1×6 down to match the height of the drawer front…
Wood Rectangle Hardwood Wood stain Automotive exterior
Have plans for the waste cuts….
Wood Rolling stock Railway Track Gas
Longer 2 will get notched to fit around the legs…and be runners for the drawer to slide on…the other 2?
Wood Rectangle Tape measure Parallel Slope
Trying to avoid them knots….will get out the mitersaw and cut a few (4) corner blocks…( may need a couple more?)
Wood Table Flooring Hardwood Wood stain
Corner blocks…glued and screwed into the corners, then a slotted hole to attach the table top..
Brown Rectangle Wood Flooring Floor
IF I can cut them close to perfect…they will also pull the corners square…Mitersaw?
Wood Motor vehicle Bumper Gas Automotive exterior
One of them Cordless Stanley No. 346 models…..
Stay tuned…waiting on the shop to cool down…
Mortises, two ways
OMG Bandit I actually used to have one of those models!
BTW HCM the most almost under used Tool in the workshop.
You know its the first tool I would sell, ... only problem is no sooner I did so I would like to build a nice table like yours.
Excellent work, ...keep it up!
Premium Member
Discussion Starter · #11 ·
Rest of the mortises, and a glue up, finally
Rest of the mortises..went something like this..
Rectangle Wood Brick Font Wall
Lay out was simple….however,,Father Murphy decided that he would pay a visit..today….
Wood Tool Metalworking hand tool Hand tool Stonemason's hammer
Ooops…not a biggie, hole will get covered by the table's top. Got all 4 square holes chopped, test fitted…decided to glue things together..
Wood Composite material Metal Lumber Engineering
Then…feeling good…decided to glue the other end up.
Loom Wood Hardwood Automotive wheel system Art
Then…the 2 long sides were glued up..
Wood Gas Automotive exterior Machine Metal
So far so good? Wait for it….I notched and glued in the runners for the drawer to slide in on….
Wood Wheel Automotive exterior Automotive tire Tire
Then, got to taking a better, non-Murphy look…..bead detail on one of the long sides..was wrong….had to go back knock that side apart, including the runner, and flip the side over, to where the bead is along the bottom edge….in the process of which….one leg lost the bottom 3rd onto the floor….more clamps and glue to fix that…grrrr…
The 4 corner blocks were sawn….counter-bored, and a pilot hole drilled….
Wood Rectangle Natural material Hardwood Lumber
So, that once all the clamps come back off….I can screw and glue them in place..
Wood Rectangle Gas Shelving Tints and shades
Then get the drawer parts all sized up..
Wood Rectangle Triangle Gas Plywood
For the next full day in the shop….drawer building 101…..decided to see IF Father Murphy had left the building, as I wanted to work on the table's top…...nope, still here…
Wood Wheel Art Lumber Machine
Had to add 3-1/2" to the width…..will need the bread board ends to make the required length…..need to trim the top's ends square, and add a tongue for the ends to connect to….
Today being a Monday…shop will be closed, until Murphy leaves the building….
Stay tuned….
Premium Member
Discussion Starter · #12 ·
Bread board ends, drawer building
Clamps came off the panel for the top of the table…..ends need to be flat and squared up. Too awkward to do the square up with the tablesaw….not really wanting to handsaw it, either….set to work with the panel clamped to the top of the tablesaw….and let a jack plane and the beltsander go to work ( new belt, too)
Wood Table Hardwood Flooring Roof
With the grain with the sander, along the glue lines….jack plane does it's thing going across the grain…worked over one face, then flip over, and do the other. Next, trim the ends square…..circular saw (6") and the tablesaw's rip fence….need to mark out how far from the fence the blade is…..and where on the panel the blade needs to cut..
First part is with a framer square..
Table Wood Plank Composite material Hardwood
Then how much room I need..
Wood Tool Gas Flooring Hardwood
Translate that to the panel..
Wood Plank Hardwood Wood stain Lumber
And clamp the guide fence in place…right on the square line….push the saw through, pressing it against the fence
Wood Wood stain Flooring Floor Road surface
mark the other end of the panel the same way…
Wood Table Rectangle Flooring Floor
Both ends are now square. Bread board needs a tongue milled….still have the panel clamped to the saw, still have the fence handy…have a 1/2" straight cutter bit in a router..hmmm
Wood Automotive tire Drill Gas Drilling
First of 4 cuts, each end get 2…
Wood Hardwood Composite material Gas Plank
Set the panel aside for the moment…
Furniture Table Wood Desk Rectangle
And measure how wide the bread board ends need to be….joint the edge of a 1×6..
Saw Hand tool Automotive tire Motor vehicle Wood
Set up the tablesaw to make a couple rip cuts, using that jointed edge to start
Wood Rectangle Hardwood Table Composite material
They then need crosscut for length….but, with Old Murphy still around, that can wait until AFTER a groove is milled to fit the tongue….just in case one end gets a bit "off"....once that is done….glue and a few pipe clamps ( and a hammer)
Wood Wood stain Hardwood Flooring Plank
And let this sit a day. Drawer building?
Set up the other router with a dovetail bit…set the drawer front in the bench vise….lay out a few pins on the end, hand guide the router to make a few cuts..
Wood Wood stain Hardwood Plank Lumber
Use those pins to lay out the tails, cut and chop out the waste…leaving the layout lines…dry fit.
One Stanley 45 is set up to plough grooves for the drawer's bottom panel…..
Wood Tool Lumber Metal Automotive tire
Front and both sides get the groove thing….back where the back of the drawer is, my other Stanley 45 is set up to mill 3/4" wide dados, to house the drawers back..
Wheel Automotive tire Motor vehicle Vehicle Wood
Dry fit?
Wood Gas Automotive tire Metal Engineering
Need two counter sunk pilot holes in each dado to attach the back..
Motor vehicle Automotive exterior Bumper Gas Engineering
I also clip the bottom corner, to make setting the drawer in place easier….then a matter of cutting a plywood panel for the bottom of the drawer….some glue and screws….glue only for the dovetails…
Wood Rectangle Hardwood Composite material Plank
Make sure the drawer is square…and set it aside….we done for the day….
Stay tuned
Premium Member
Dry fit?
Stay tuned
"Use those pins to lay out the tails"
I am confused, I recently converted to a pins first on dovetails but figured I would still need to do tails first on half blind so I could mark the pins. So hoe do you use the pins in the drawer front to lay out the tails?
Either way it is looking good Bandit!
Premium Member
Discussion Starter · #14 ·
Dry fit?
Stay tuned
I use a sharp pencil to trace around each pin. Then I cut on the waste side of the lines…more line I leave, the tighter the fit. One hand for the pencil, one hand to hold the parts where they need to sit…..and my chin to hold things still long enough to make those pencil marks…
Premium Member
Dry fit?
Stay tuned
Is here enough room in the half blind pins that are in the drawer front to get your pencil in there. It just seems like it would be tight and awkward.
Premium Member
Discussion Starter · #16 ·
Dry fit?
Stay tuned
Plenty of room…for a sharp point of a pencil….as the tails are a bit wider than the pins..
Wood Rectangle Floor Hardwood Tints and shades
Motor vehicle Wood Auto part Gas Engineering
Wood Tool Gas Machine Toolroom
Premium Member
Discussion Starter · #17 ·
Time for a PIP
Once things were sanded and planed smooth..was time for a coat of stain to be brushed on….
Wood Rectangle Natural material Wood stain Hardwood
Some spots needed a bit more than others…..wasn't just a plane, or a sander used..
Wood Hand tool Tool Metalworking hand tool Hardwood
I also gave the Stanley No. 80 a little work. Each of these 3 tools were used where they fit best. Had to clean out the shop a bit….so I could set the table up on the tablesaw, rather a towel sitting on the tablesaw's top. Wanted to be able to rotate the table, without scratching up the top of the table..
Wood Rectangle Hardwood Wood stain Varnish
Everything except the top itself got a decent brushed on coat….allow to dry a bit….then wipe down….and let it sit a day….next day, set it down on the floor…
Furniture Table Wood Outdoor furniture Wood stain
And gave the top a coat of stain. Colour is called "Gunstock", BTW.
Let things sit a day….sit the table back up on the tablesaw on it's top. Coat of Clear Gloss Poly was brushed on, allowed to dry overnight. Next day, flip over and varnish the top….
Table Furniture Wood Rectangle Desk
Allow to dry, hand sand with 220 grit, rub down, and wipe off. Then brush on coat #2, allow to dry most of today, rag to rub the top down….calling this done….
Table Furniture Outdoor bench Wood Outdoor furniture
Fun part was hauling this up the stairs and out to the back patio, where the Gazebo was waiting..
Furniture Blue Wood Chair Flooring
And that will do for this little project…..will have it posted later, today.
Overall size? stands 25-1/2" tall….top is 3/4" x 19-1/4" x 32" long
Thanks for looking in!
1 - 17 of 17 Posts
