A New Beginning: Design & Build from scratch...
60543 Views 28 Replies 16 Participants Last post by  daltxguy
6
My Journey Designing & Building from Scratch
For quite some time now I have wanted to build a piece of furniture from scratch. This is partly because I could not find any one plan that suited me and because there are SO MANY things I just don't know. Many folks like to "Prototype" or build mock-up's / models. I wanted something more and something quicker and less expensive. That is were my Sketchup journey began; I started by working through the tutorials, then asking a whole lot of questions. Several of the most vexing issues where answered right here on Lumberjocks. I.E. how to use that lovely tool called "Follow-Me". As a side note: It is well worth your time to learn that one…
Last week I started spending a little more time each night trying to learn the basics and working through some of the issues. After the "Follow-Me" questions my biggest issue was pulling the whole piece together; I could not seem to get everything in the same plane no matter how hard I tried. To call it annoying would be a huge understatement! Then I watched a video on the Wood Whisperer's site and it suddenly clicked (Thanks Marc!) . Create the whole thing upside down! then flip it upright.
I was finally able to put down on paper what had been rattling around inside my head for so long. I wanted something with nice clean lines, you know, uncomplicated….
This first view is just the table in general to show the basic lines; this design was heavily influenced by several different pieces I have seen over the years and what lumber I have on hand.
Next, a shot that, I hope, shows off the reveals and shadow lines.
This is a view of the beveled table top; it is 3/4" with a 1/4" edge remaining.
I picked up a 1/4" beading bit on clearance @ Woodcraft and played with it a little; this is my attempt at reproducing that edge detail.
I really want to produce everything for this desk myself. So, I designed the drawer pull and inserted it in the drawer face. What do you think? By the way getting it properly referenced on the face was very tedious.. Anyone have pointers on that front?
After getting the pull in place I thought I was done. Apparently my brain didn't think so! It just looked plain and incomplete (I literally stared at this drawing for an hour!). That's when the idea to add the leg beading popped into my head. It is situated to where the bottom of the beading is just at the line where the leg taper stops.
My next installment may be a little while as I now have to actually work with the wood. I don't own a power planer or jointer so this effort will be 70% Galoot style. Jointer Plane, Jack Plane, Smoother Planes coupled with my bandsaw, tablesaw & lathe. Should be fun!
The results to date just would not have been possible if not for the help all of you folks have provided so willingly. Thanks Everyone!
1 - 20 of 29 Posts
Nice work Chris!
Now just because you can design it doesn't mean it can be built LOL.
Bach was known for writing music that most musicians couldn't play.
But in all honestly, this looks quite doable. The second part of the fun is figuring out how to execute.
But it didn't stop him from trying, did it Scott? :)
Actually I was trying to come up with a design that was doable with the tools I own but would stretch my skills and maybe force me to learn a few new ones.
C is a beautiful project.
I like it, and I like how you stayed with the SketchUp steep learning curve.
Looks like a nice table, good luck Chris. Looking forward to the completed or even the up dates, while you work on it.
Thanks Guy's!!!
Chris,
You've done an excellent design layout for your table. Nice work!
About your SketchUp question on placing your knob: Try using the tape measure tool (or any method you prefer) to mark a center point on your drawer front. Then measure the radius of your knob handle (small part that will attach to drawer) and mark it on your drawer front below the centered spot. Move your drawer handle by locating the bottom center of the handle and placing it on the spot you've marked on your drawer front.
I hope this might help you. If I've not communicated this concept clearly, just ask again. I know how you must be struggling because I know what I went through with no one to teach me. I have dial-up internet which is so slow that it would take days to download video to watch, so I've had to just teach myself. When I finally get an idea that works, I feel relieved, but I often go to bed dreaming in SketchUp mode and trying to determine other methods to simplify the process. It can lead to nightmares or sleepless nights!
Thanks LadyLeftie…... I'll have to try it out.
You've probably already thought of this, but when David Marks did a leg bead like that, he dadoed a groove into the leg so that the bead was actually considerably "taller" that it appears. He also did it before he tapered the legs to take advantage of the still square surfaces. This beading method has two benefits, first the bead is secured and registered, and there's more mitered surface area to hold the joint together. Great design! I've mastered AutoCAD, but still can't figure out SketchUp. Feature that.
That's exactly how I planned on doing it…
4
Just being a Galoot.......
So, yesterday afternoon I started really working on the project. I had ~10BdFt of 8/4 White Oak on hand so I rough cut it to length on the table saw then started flattening the faces and jointing the edges. When it's about 90 - 95 Degree's(f) and 90% humidity it can make for quite a workout & weight loss program. I have the blanks for the aprons and legs ready to to re-saw on the Bandsaw. There is no way I would try that by hand with a rip saw; I'm not the twisted!
A flattening we will go, A flattening we will go…..
How square is that edge?
About that square!
Stop to cleanup, then keep going…..
Of course this is the VERY much shortened version of this effort I'll update again as it all progresses. For now it's just me and my planes (oh, and bandsaw).
About that square!
I can certainly appreciate 95 degrees with 90% humidity … been there, done that … it's not fun. I'm impressed with you patience in truing up your boards with hand tools. I ain't got it and impressed by those who do. So far, so good.
3
The Top - It has a story of it's own
I actually glued up the top more than a year ago from some old growth Oak that I had salvaged. Therein lies the story; not long after my wife and I were married and moved into our house we were offered an old upright Piano for free. My wife was a voice major in college and of course jumped at the opportunity. All I had to do was drive up to Jekyll Island Georgia to retrieve it; however that was easier said than done. Have you ever seen one of those huge old uprights? This Piano had Mfg. date on the sound board of 1903. This thing was about 5' 6" high by ~6' long and boy was it heavy (took six people to move it) but it sure was pretty.
It was old growth oak veneered with amazing tiger striped Oak; the keys were actual Ebony and Ivory. Well, you get the picture. Fast forward a few years and it's 2004; we suffer the painful loss of our house and all the contents in a fire. The piano was badly scorched and completely ruined with water damage. Two days before demolition began I went back into the wreckage of our home and recovered as much of the old growth Oak as I could. It was just me, the soot, lots of mold & mildew and a few hand tools. some of it was single pieces and some were glued up panels from different parts of the instrument; such as the lid. I let them dry out at my parents house for several months then planed the scorched veneer off and found the most beautiful fine grained Oak I've ever seen. It has worm holes in a couple of places and other "character" marks. I went ahead an glued it up into a large panel waiting for the right use. My wife will get this desk to use for her sewing and crafts and to remember what we have both lost and gained.
Great story. I am sorry for the fire. Looks like you've manage to save a real treasure. I can't wait to see more of your desk build. Thanks for sharing Chris.
I look forward to watching the progress on this.
The wood looks similar to wormy chestnut on my little laptop screen.
I agree with Todd. Not sure but what it is something other than Oak, but it sure is pretty and that is an amazing love gift to salvage it and make something else as a gift to your wife. Almost looks like Red Elm as another possibility.
It looks like you're going to have a beautiful desk when its done.
I'll be watching for future updates.
Well, It has the very similar open grain to Oak. Even if it is not (I've been wrong before) It's still going to be the desktop. :)
Thank for the input everyone!
2
Two Steps Forward, One Step Back.....
So, after getting started on rough dimensioning the lumber I decided to go back to the drawing and complete the prototyping in Sketchup. I have added the corner blocks / braces to firm up the leg to apron joint (that should resist racking; correct?). I have also created the Drawer guides/glides and have them placed in the drawing. I'm pretty much flying blind other than some reading I've done. Also, does anyone know of a decent tutorial for using intersect in Sketchup?
Does any of this look wrong?
1 - 20 of 29 Posts
