Project Information
I started brain storming again trying to reinvent the wheel or should I say my wheel anyway on my already hybrid bandsaw box design (valet box), by adding the slab draw fronts replacing the blade cut rounded corner fronts, I think this gives a newer, sleeker design and a cleaner look, though they both aren't bad, I think I like this new look better, I wasn't sure of the mitered and splined corners with this change so I did a butt joint but will incorporate on future boxes mitered and splined joints, another feather change is the tray over the false bottom door which I hadn't been doing, this will allow a quick removal of items in order to access the hidden compartment.
The rest of the features are the same as my previous valet boxes with two large open trays on top, two large drawers, a hidden drawer inside of the large drawer and the small pull out tray acting as the key to access the false bottom door by way of magnets.
The box is made out of Pecan with knotty alder on the inside as the core and Wenge for the pulls, the Pecan, I cut via chainsaw from a neighboring town on friends property, the box measures 12" x 8" x 5" a very nice large valet box and has plenty of room for storage, I have also changed up my finishing process, I first laid a quick coat of tun oil, (dried) then a nice even coat of non waxed shellac to aid the tung oil in sealing up the end grain then came back with 3 coats of satin wipe on poly and a final coat of paste wax.
Thanks for looking and comments are always enjoyed reading and replying too.
