Project Information
I was goofing off on the lathe today, and with nothing more to turn than a few small pieces of redwood I popped this thing out. I have a desire to make a full size hollow form sometime, so this was a bit of practice… I custom ground a tool just to hollow this bad boy out. I would say the thickness is around 1/32" or so… probably 3/32" on the bottom.
I think I may be able to get the title of world's smallest vase.
Gallery
Comments
· Registered
Very cool
· Registered
Now I like doing small turnings, but this is tiny!
Great job.
Keep it up.
Scrappy
· Registered
Hi please give sizes Hight & diameter
Regards roger
· Registered
Wow. I'm impressed with that thin a wall thickness and on such a small piece. You must have made a little bitty tool!!!!
Nice job and I think you get the title!
· Registered
tamboti, the size is appx. 3/4" diameter, and the height is about 1 1/4"
· In Loving Memory
Wow, that is tiny. You must have some nerve.
· In Loving Memory
How did you chuck that, just use a big piece of redwood and work on a corner of it?
· Registered
I had a piece of redwood cut square about 1" and about 5" long… chucked it up and turned the end of the blank into the piece… The hollowing was done through a hole a bit larger than 3/16" which is about as small as I could go with the custom scraper.
