Project Information
I got started with hand tools after getting my grandfather's stanley #5 and #6, but lightweight workbench were not up to the job. I used construction lumber to save money on my first try. Laminated 2×4's make up the two top sections, which came out roughly 12"x3.5"x6'. I used a power planner for that. The legs are laminated 2×6's with through mortised end stretchers. I tried out wedged dovetails on the length stretchers. They tightened up OK but aren't as rigid as I want. I would definitely do wedged mortises next time. I planned on setting a block into the legs and top but I couldn't get them to line up so I trimmed them off and used large screws instead.
Gallery
Comments
Nice use of relatively inexpensive lumber. This bench should serve you well.
I see dovetails…thats a bit on the Gucci side hey what!
The timber lives on!!
Seriously now,
great effort and result
it looks rock solid too
what glue did you use on the laminations?
Dude,
For your first try that looks great. It's a work bench. I wish more first timers see this because this is an excellent example of building something that will help you to continue woodworking and building . That is how it is done.
Great job.
Marty
Nice job. Looks like the same HF vise I have in that last photo!
I like it. Looks to be more heavy duty than my second girl friend!
Looks very sturdy and will last for a long time, thank you for sharing
Looks solid. No rockin when planing.
Functional.
To me good design is something that can be used.
Some workbenches are gorgous ! BUT they are show pieces.
You will get lots of use out of this !
