Project Information
When I first started to build my Shop (it's not a garage, it's a Shop) the only bench I had was a 3'x6' folding table. It worked great for a couple of years. After looking through woodworking magazines for a couple of years, I decided to build a workbench. For me, simple is best. I also wanted to use it as an assembly table and an extension for the table saw.
I used 1"x 4" pine for the legs, feet and top cross-pieces. I glued them together to form a 4" x 4". Well, really 3" x 4". They are really strong. Made mortise and tenon joints so everything could fit together. Actually, at glue up I left spaces on the legs, feet and top cross-pieces so I could just slip them together. I glued and screwed a piece of MDF to the top cross-pieces. I put a piece of ¼" birch plywood on top of the MDF. Using a prefab maple butcher block top I placed that on top leaving about 6 " from one side to make a tray. I bought the prefab maple butcher block top since the cost of stock maple was more than the prefab top. Then I used maple to edge the entire bench. One nice little tip: cut some ply for the ends of the tray and install them at a 45 degree angle. That way you don't have a 90 degree corner that makes it difficult to pick up parts or keep clean. You can just slide any screws or parts up the ramp from the tray. I added one more tray under the bench which is used to house boxes of screws or nails.
There are two stretchers one for each leg. On top of the stretchers is a shelf. I could have bolted everything together to make it portable, but I glued and screwed it together.
Its one strong bench and it won't go anywhere.
Gallery
Comments
· Registered
Nice, Fred. I'm guessing that, since you call this a "work table", it's not your bench. Seeing no vise, or bench dogs, what is the primary purpose of the table? You mention assembly and TS extension - what else?
· Registered
Fred,
That looks really good and sturdy!!!! I like the idea of the 45 degree angle in the tray..
· Registered
Come to think of it I don't have a vice or bench dogs on my on my work bench. Good looking table.
· Registered
I like all tables, benches and the like, because ….......I don't have any. Maybe the Princess will have pity on me and give up her car space. Not likely.
fred, I like your work table and bench. I hope that I'll get there some day.
· Registered
I like it. For grins you could drill a few dog holes and add some wonder pups.
· Registered
sounds like it serves your purpose - perfectly!! Great design
Bill.. take a look at Obi's table-you could suspend your table from the ceiling!!
· Registered
Very nice! I love the simple design and implementation. Makes me want to make one for myself.
· Registered
A nice bench indeed. I need to make one for myself too.
· Registered
I have since added an undermount vice in the top right side of the "table". I haven't found the need to add bench dogs yet. I assemble all projects on the table and I can access all sides of the project. I put a drop cloth over the table and put on some "T" stands and do my painting and finishing work.
The "T" stands are made of 3/4 plywood. I also use the "T" stands (6"x36") for glue up of the projects. That way it is easier to clamp the bottom of a project and from all sides.
The dimensions are 62" x 33" and it is 34" high.
· Registered
Nice work table and thanks for the tip!
· Registered
Good idea Fred, double duty for the workbench!
· Registered
debbie…then she could see up my nickers :)
· Registered
Really like the tray-good design. Really debated putting a tray on mine.
Scott
· Registered
Nice bench, work table, paint stand, Good job Fred.
· Registered
Fred
Nice work bench. I built a very similar bench myself. Same type of frame and top. Used it many years.
· Registered
Looks great hope it serves you well for years to come
