Showcase cover image for Woodsmith Router Mortising Jig
Project Information
I decided that I needed a mortise jig before I started my next piece of furniture. This should make mortising quick and clean. I took the plans from Woodsmith #147.
First picture was before I installed the T-track.
Photo 2 shows the 4 adjustment blocks that you use to size the mortises.
Photo 3 shows the vertical fence. There is a slot on the upper portion so you can change the angle to past 45 deg if needed.
Photo 4 shows the horizontal fence.
Woodsmith put up a video showing how to use it, which also shows the basic construction for anyone who doesn't have the plans.
http://www.woodsmith.com/magazine/extras/147/setting-up-and-using-the-router-jig/
Gallery
Comments
I need a mortise jig too. good job.
Nice. I'll have to add this to my project list. I'm a subscriber to Woodsmith also, but not sure if I have this issue though. Have to check. Nice work.
Looks like a nice built and very useful jig.
Wow, that is really cool. Great job
Very nice job,that will make life a lot easier when doing M&Ts
Thanks guys. I will be replacing the washers with wider ones, and cutting down some of the excess bolt length since it's not needed.
I will be making a woodgears tenoning jig to pair with this as soon as I get some hardware in. My hope is that I should be able to get very accurate M&T joints every time with these 2.
Nice build
Dang man, that was fast. Looks pretty handy.
Looks like a interesting jig but the video was a little skimpy on the results .
Glad to see you are using a plunge router for this .
Do they have plans for this?
I see the basic construction in the video, but I'm not seeing any plans for sale. Is it in the magazine?
To answer my own question…
No they don't have individual plans for this.
Yes you can buy back copies of the magazine - But they're only available in select volumes, otherwise you have to buy the whole 35 year set for $99.
I just want the one article for crying out loud.
