Project Information
These tools were made out of necessity. I forgot my collets for the lathe so I needed to mount my buffing wheels away from the chuck or the head stock so I made this mesquite mandrel to mount the wheels in. I first turned the #2 Morse taper and did the fitting in the tail stock. Then I mounted it in the spindle and bored the 1/4" hole and tapped a hole for a set screw. It works just great . I have since put a screw in the end of the Morse tape to take the hits from the ram rod knocking it out. I would not want the wood split or mashed from knocking it out
The second tool is a wooden sanding ball where I put a piece of sandpaper over the end and hold it on with a rubber O-ring. I needed this for some spoons I'm making. I have to make some more of them with a 1/8" arbor for a Dremel. but I may need the metal lathe for that. This was also made from Mesquite.
Cheers, Jim
Gallery
Comments
Premium Member
great tools Jim - the spoon tool will save me buying some carving knives - thanks for the idea
What wonderful ideas Jim.
I have to make some of the sanding tools.
Best of my thoughts and Merry Christmas, to you and yours,
Mads
Cool tools Jim!
I like both of them and might borrow the second one.
Thanks for sharing.
Nice going Jim! Thinking outside the box again I see!
Awesome idea Jim! I will need to put this on my after Christmas to do list.
I like the o-ring idea. Makes it much easier to replace the sand paper.
we are on the same page, or great minds work alike, I was doing somewhat similar today, working up a system for the three stages of buffing. My homemade lathe does not have a Morris taper in the headstock. so I took a 1 inch coupling nut, screwed a 6 inch piece of 1 inch redirod into it, then lathed the end down to 5/8 and cut a fine thread on the end. tried it on the lathe with an 8 inch buffing wheel and it worked ok. first one I welded, messy, second one I used red locktight, Need to make one more then will have one for each wheel and grit. Wood one is great for small wheels.
come to think about it, I have a collet set for #2 taper. could use it on my small lathe for holding a buffing wheel.
Varietx of orfers is your speciality too!!
Handy tools to have for a busy guy like you Jim!
I have to hand it to you Jim that mandrel is pretty slick. The sanding ball idea is cool to have. Anything that hjelps with sanding is great.
Thank you all for the nice comments. I hope they may have sparked an idea for someone else who needs that sort of thing. I sure miss my Southbend metal lathe but I can still make tools on the wood lathe.
Hi Brian, I made a similar set up for buffing in my Nova lathe. I have a 1 1/4"-8 nut welded to a 8" piece of pipe and there is a 1/2"-13 thread in the end. all my buffing wheels are mounted on a 1/2-13 bolt and I just screw them on and off…....................we sure do think alike!!!!!
May you all have a Merry and Holy Christmas and Happy and better new year than 2020!
Cheers from our shop in Arizona!!!!!!!!!!!!!!!....Jim
Very resourceful.
Thanks James and Swirt…..................Cheers, Jim
Great idea Jim
Thanks, Tony….........Cheers, Jim
well done Jim….Great Idea!!!!!
Regards…...Cliff
Thanks, Cliff…I have used them a few times already…especially the buffer mandrel….............Happy New Year, Jim
