Project Information
Tool-making bug is itching me. Earlier I said that I needed router plane for my workbench build, but what the hell, I just wanted to own one. Honesty is the best policy
Here is my starting point: cutter with threaded rod and milled facets:
Since I had no "real" cutters available here for any reasonable money, I needed to make one from scratch. On one hand I didn't like usual option - L-shaped hex wrench, and on the other hand I wanted some adjustment facilities, so I came up with this solution: to weld tip of the chisel to the threaded rod (10mm diameter). The idea was to minimize number of parts involved into design, and since I had to make the cutters anyway I decided to give it a try. This was the most expensive part of the project: 6 chisels (4mm, 5mm, 6mm, 8mm, 12mm, and 16mm), plus metal turning, milling, and welding work (that I had to outsource) took me about $80. I don't know how chisel tips were welded, I just asked guy who did it for me to try not to overheat cutting edges. Will see how my cutters gonna hold the edge. Also I spent quite a bit time truing up cutters geometry, but thanks to DMT stones it wasn't too bad.
Having cutters ready I made a bolt that holds the cutter:
The adjustment nut had to be re-shaped slightly, so I employed my poor-boy lathe, this time cutting brass with sharpened tip of the file:
Next I made a prototype out of pine:
The prototype was very right thing to do, it let me to test all my not-so-good ideas before I found something that would work for me.
Next was plane body (beech).
(Main hole drilled with the help of sacrificial piece of wood. The drilling is still my weak spot, I guess I need a drill press.)
(Templates like this one was another right thing to do.)
Ready for shaping:
And here the shaping starts:
Checking shape against the template.
Here's my favorite one: prototype is being used as a tool to build a tool it's been prototyped for:
Sanding.
Two brothers:
Brass work.
Brass stripes glued into cutter-mounting hole to protect wood from wearing:
Back side of adjusting nut cover plates and back washer:
You can see that I had to hammer brass parts to adjust their shape for better fit. Turned out that metall allows for some errors as well as the wood.
Bolts' heads re-shaped from hex to round:
Handles.
Handles turned on my poor-boy lathe from some unidentified wood from my mom's garden.
One ready and one more to go:
Final shape of the handles: more smooth curves to match plane's body:
Reaming handles with some ugly bit made from bolt:
Despite its ugliness it provided perfect recess for the head.
Drilling holes for the handles.
Here's how I made little recesses for the handles: I glued sandpaper at the bottom of the handle, screwed it in place and kept rotating it until it cut its way down in the plane's body. Then removed the sandpaper.
All parts in place, ready for finish:
After two coats of danish oil:
And finally some tool porn for the brave who survived such long post
Plane in action:
Couple of words about how adjustment works. It works great! I think adjustment machinery is quite clear: you turn adjustment nut which is locked in place with cover plates, the adjustment nut pushes/pulls the cutter up or down. The threads on the rod/nut is 1mm step, so one full turn of the adjustment nut gives 1mm (a little more than 1/32") of cutter move. So if I need to go 0.25mm down I do 1/4 turn and so on. Cool! And this little dot on the adjustment nut helps me to track cutter move:
Thanks for stepping by, being a happy owner of the router plane now I'll be happy to answer any questions about one
Ready for shaping:
Sanding.
Two brothers:
Brass work.
Handles.
Plane in action:
