Project Information
When I joinrd FLICKR some months ago, and since joining Lumberjock I have become more aware of the inadequacy of my Photography. I decided, therefore, to take it more seriously, especially with regard to photographing my woodwork which is my main interest.
One problem is how to hold the camera in any fixed position:
- for long exposures
- to avoid camera shake
- to enable repeated shots
with varied camera settings
I looked around for something suitable. I wanted something like the robot arms seen in videos of car manufacture for example, but could find only the usual tripods which I find wanting as they are not flexible in use. Therefor I designed the "Macpod". (apologies to Apple Computers and Macdonalds)
Macpod - Base
I made most of this with 3cm X 1cm walnut and Mahogany stock from the local DIY store since at the moment I don't have a thicknesser.
Arrange and glue some pieces to form a roughly circular shape about 7" diameter, leaving two spaces 3cm long for the uprights later
Macpod - Base
Hollow out the waste side
Macpod - Base
Hammer some nails at odd angles into it (to hold the cement ballast later). Laminate some veneer round it.
Macpod - Base
Fill the base with quick drying cement
Macpod - Pantograph
Cut all the stock to length, round ends and bore holes for bolts There are also spacers of 1cm square walnut not shown here.
I used 8mm hardware, a bit bigger than 1/4"
I recommend great care at this stage (e.g. use jigs)
Macpod - Pantograph
Check rounding and holes alignment Glue in walnut spacers as shown
Macpod - Base
Detail of joint
Macpod
Completed Macpod, the camera holder I cut off an old mini-tripod and apoxy-resined it in a hole I cut in the small piece. With this and the flexible arms, the camara can be pointed in ANY direction
.Macpod
This is the setup in my studio for photography with a black sheet on a roller hanging down over my workbench forming a horizon free backcloth
Gallery
Comments
Great project Mac, and fully documented. What else can a man ask for?
Best,
Good design and workmanship.
BTW - is that a Mamiya Sekor 35mm?
Very nice! All your effort was well paid off. The funny thing is, one of the most famous camera tripod companies in the world is Manfrotto in Bassano del Grappa, Italy.
Thanks Jim
No Joe it's my old film Canon with a Tamron 35-80 zoom., I just dusted it off to use as a model
Thanks for the info chris
Premium Member
I like your design. There are so many times when a tripods legs get in the way of photographing a subject.
Great design en very useful. Well done!
I can see many uses for it around the shop besides holding a camera. Nice work.
Did you make 2 so you could take a photo of one while using the camera on the other? (that was a dumb joke…)
Looks rad! Did you consider putting a swivel in a the connection between the base and first "arm" piece? I guess the tripod attachment solves the rotation issue…
great holder you have done there it realy can be adabbed to a lot of other uses too
thank´s for sharing
Dennis
Excellent post. Well documented and great photography. Thanks.
I love a piece of art (Macpod) that helps you create other pieces of art (your photos). Nice work!
thats nice!
Super design and great build
You have some of the best ideas!!! Thanks for posting how you made it , I'm going to make one..
EXCELLENT! I favorited it.
This is fabulous! I surely need one for my photo work.
From the begining, I liked the idea. With my all photographing problems, you left me without any choice but to make a "camira crane", like yours, for myself. Thanks for sharing your idea in full details.
Love it, especially the cement base and your excellent description and photography of the project :)
Added to favorites for certain!
