Showcase cover image for Wild Cherry Black Knot Fungus Box
Project Information
Using another piece of gall wood that I found, I used my clamp system and Sawzall to make the box shape (which I then ground more or less square with my grinder.
Cut the lid off with a pruning saw.
One change? Instead of having the inside be a bowl, I used Forstner bit to make the inside a little more box-like.
I'm pleased with the results.
Gallery
Comments
In the spirit of Halloween's month, I'm toying with the idea of adding this skull.
Opinions?
Man, you really find some great looking chunks of wood…
Good looking box, keep it up, very nice…
Thanks! I think the wood masks the imperfections of my process! The wood certainly doesn't look like much when I find it, but I know the gold underneath.
- mtnwild
Gorgeous work is an UNDERSTATEMENT!
That belongs in an art gallery!
Thank you so much! That means a great deal to me.
- ralbuck
So a piece like the one in your hand is similar in size to the boxes you have been posting? I guess I thought you were using larger burl sized (bigger than a bowling ball) pieces.
The one in my hand wouldn't make a very large box… probably is too small.
But the pieces I use for the boxes are probably the size of say a football?
They shrink quite a bit when that nasty bark gets cut away.
- therealSteveN
The figuring and spalting give your piece astounding character.
Thank you! I very much believe it is the wood (not the woodworking) that draw people to what I'm doing.
- SuperJoe
Looks great. I like the look of the deeper storage using the forstner bit.
It's definitely one of a kind! Did you stabilize the burl?
I did not stabilize it.
