Project Information
Well, finally I found the time to post this project. It was a big one.
It's basically a reproduction of a cabinet that my Grandfather made in the early 60's. It's made from high quality walnut plywood, soild walnut and some birch for the the drawers and shelves. The finish is Watco Danish Oil (natural) and Bees Wax polish.
Overall, it went fairly well with very few mistakes. I could go into a lot more detail but I'm not really in the writing mood. Anyways, hope you enjoy and feel free to ask lots of questions if you have any.
Thanks for listening!
P.S. I'll post some better final pics once I have them. Sorry for the crappy finished shot.
Gallery
Comments
· Registered
Nice work, I'd say more but I don't feel like writing it. :p LOL
· Registered
Really fantastic, I've added it to my favorites. I'd like to see more detail about how you did the sliding doors, and what method you used to cover the plywood edges (solid or edged?). I'm impressed with the splined miters, was it difficult to get the splines in the right place to keep the miters aligned?
· Registered
Your grandfather has a great eye!
· Registered
RyanS,
The sliding doors were fairly simple. I just milled down some 3/16" walnut strips for the rails and in the top of the base. The doors have a matching groove on the under side. The top of the door and underside of the cabinet have corresponding dodoes with lots of clearance so I can lift the doors and take them right out.
The splined mitres were a bit tricky. I cut the mitres first of the table saw, then flipped the piece over and cut the slots. One side was not aligning properly so I had the cut the slot with some wiggle room which was not ideal. In the end I shot some pins into the sides so I'm pretty sure that held everything together, at least until the glue set. I think if I took more time on the table saw and moved more slowly it would have turned out better.
Thanks for your interest. Answering questions is a lot easier than just talking about your work.
· Registered
UPDATE: New pic of the final has been uploaded.
