Project Information
On each trip I make up to NE Oregon to see my Grandsons, my daughter picks a project for her, the boys, and me to make. Last spring it was a kid sized picknic table, this winter (the weeks before and after New Years) she wanted a TORTILLA PRESS. We searched the web, talked to several friends, and random Hispanics, and came up with this idea. It is made from 4/4 Hickory and Walnut. The handle is two pieces of walnut laminated together with the grain, while the plattens are laminated cross grain for added strength. We placed our favorite brand of tortilla between the plattens to space the hinged side, and then found silicon rubber stick on feet the right thickness to space the other end of the plattens. The same feet were used as feet, and as a cushion under the handle/press lever. The finish was Howard Butcher Block Conditioner from Big Orange.
Gallery
Comments
Now that is one fine and fancy tortilla press!
Nice job Doug!
I have recently started making my own tortillas… This looks like it sure beats using a rolling pin…
Good gracious - that thing looks like it will squash a penny flat!
When in doubt - overbuild! ;-)
That thing looks, and I'm sure works, wonderfully!
-bob
Very nice - so does it work as good as it looks?
Wonderful job, I realy need to make me one of those.
Thanks for the comments, guys!
Knotcurser, I am going to try one a bit thinner to see how it works. This was made of 4/4 S2S lumber at my daughter's house. She (her husband, actually) has a shopsmith with bandsaw, so we could not resaw the 8" lumber. We laminated the plattens at 90 deg for strength. I will try resawing 4/4 lumber in half then laminating it back together at 90 deg to see if that works. It would save a considerable amount of weight. I will post the next one when I do it (other projects in the queue ahead of it).
Hey Doug,
question for you since the press has obviously been around awhile… Looking at it, there doesn't seem to be 'any' room for the tortillas … I realize you want pressure to flatten the Masa but my mind says 'leave a gap' of 1/8" or so.
What has been your experience with using that as it stands?
