Project Information
Although the wife liked the first ring she wanted to see more of the walnut, so I whipped this up. These things aren't the easiest to make but the system I've made for them makes it easy to make multiple blanks at once which is a good thing since there are small ring fragments here and there as I experimented with what system works best. Once I figured it out there were no more broken rings. For size, this is a size 5 meaning it won't even fit over my pinky knuckle and the walls are between 1/16 and 1/32 so about 3/64, it also means that the pictures are way bigger then the actual object. Without the offset segments these things would fall apart but if the segments are properly glued and offset the dremel can fling these suckers 20 feet without them breaking.
Once I had down how to do it a parishioner came over with his son, the son wanted to make one for his girlfriend. I didn't get a pic of the son's which was purpleheart with walnut center. However the father wanted one for his wife and that produced the final pic, a combination of padauk and walnut that looks amazing, his has walls that are about 1/16" thick and is about a size 5.5; he was worried about going thinner. All three rings were produced in 2.5 hours with me explaining the steps.
The only downside to the whole process is that I think I've ground off half the prints on my fingers and replaced them with superglue.
Gallery
Comments
In Loving Memory
Very cool!! I like this one better than the last one, I like the last pic too…!!
Looks like you have been hit with the ring making Bug! I don't think they make a shot to cure that.
Ring making can be addicting.
Nice job and Nice Pics!
Keep it up!
Wow! Super nice ring. Nicely done. Good luck in the contest.
Fabulous rings! Like most the last one, you have already mastered making them. Great job!
-www.sawblade.com
Very NICE and intricate!
A little more light on the subject would have been better… to see the woods better… BUT, OK…
That is SMALL!!
Thank you.
