Showcase cover image for Under Stairs Drawer Unit
Project Information
This was a paint quality project that required right and left units. Anything that has an angle like this increases the difficulty because there are no 2 things alike and this requires a lot more setups. And you need detailed drawings for all the components.
Gallery
Comments
Is that you in the photo? Where does the other unit go? Is there access to both sides of the stairway?
Premium Member
good looking results, nice fit.
Curious as to why you didnt make the dept of the draws the full width of the stair case width?
I've see cabinets under stairs before but they are typically built into the stairs….....if that make sense. I have never seen them built as a unit before and then slid into position. Very clever and yes, it takes a lot more measuring and attention to details.
Well done.
This is pretty amazing. I would have built it in place and formed the drawers around those dimensions.
Your method is probably way better.
Nice build.
Clever solution.
Premium Member
Nice cabinet.
These add so much valuable storage, thank you for sharing
