Project Information
I am an amateur woodworker and I just finished a Tuscan trestle table for a friend's small Italian restaurant, and thought you might be interested in it.
-made from old salvaged attic floor timbers, lots or worm and powder post beetle borings, very heavy old growth wood
-made to be easily disassembled with no tools as the complete table weighs approximately 500 lbs
-joined together with dovetails, mortises and walnut wedged draw pins
-original design to reflect my friends concentration on simple, authentic hand made foods in his restaurant
table is 31" wide, 9 ft long with a 1.75" thick top
table completely disassembles with a mallet in minutes
top is dovetailed to the leg tops (a tight slide to facilitate expansion, but not loose)
leg tops are mortised to accept the leg upright and held in place by the tops heavy weight (250 lbs)
upright sides are glued up laminates of red oak on a center core of plywood and sides are 3.5" thick
side feet are 5" wide and are mortised to accept the side upright
trestle ends are tenonned into the leg side mortise and pulled tight with wedge draw pins
leg ornamental center sections are book end sawn walnut along with the carved trestle draw pins
trestle center section has my friends name carved in with scroll work
table is finished with a thinned down polyrethane boiled linseed oil mix (multiple rubbed in coats) followed by a bees wax polish
