Project Information
I've become interested in the design elements of Greene & Greene of California fame. I made three memory boxes for some of the grandchildren each applying different elements for practice. The first is spalted apple and uses the proud pillowed finger joint. The second is maple with the top and bottom being breadboard ends with walnut pegs and splines. The third is walnut with the front including a cloud lift that I extended into the top. It also includes my first attempt at inlay, which is nothing like G&G's wonderful inlays. Hopefully with the obvious differnces between boxes and each child's initial carved on front (my first letter carving) there won't be any fighting over whose is whose.
Gallery
Comments
You call this "practice"? Looks to me like you've got those techniques down pretty well. The thired is my favorite.
Nice Phil,
What's your finger joint technique?
What did you use to inlay those nouveau poppies?
Scott the finger joint is cut in any way you prefer (table saw or router). The trick, which is Peart's not mine, is to do an extra f/b and side that will be a throw away. When pillowing the fingers assemble with the spare f/b or side and sand away without worrying about marring the face with your sanding. A friend tried rounding over with the router but the hand-sanded pillowing is much more appealing.
The inlay was using the router inlay kit.
Nice job one the box. I like the inlays
I have found it difficult use Darrell's technique to make the fingers different sizes like I did on the drawers for my night stands. the fingers are progessivly larger as they go up. I did use the pillowing technique (extra throwaway) and that worked out nicely.
Nice job. Is the material for the inlay holley?
Yes Scott the inlay is holly. You've got me thinking about the jig set-up for cutting progressive sized fingers - interesting.
I like the boxes. I'v never seen spalted apple before.
I also got the G&G bug and I'm planning to make a bedroom door and bedroom set out of walnut. The aurora dressers are nice but i'm not that crazy about the beds. Have you seen any G&G beds that you like?
