Project Information
A few months ago I built a TARDIS nightlight for my son who is a fan of Dr. Who (see projects). My daughter, knowing her birthday was coming up, asked for a soccer ball nightlight. I laughed and told her that would be almost impossible to build (knowing that I had seen some balls built on Lumberjocks). Well, I undertook the challenge and I can say it was very difficult. I chose quaking aspen both because it is soft and easy to work and because it is very white. I decided to leave the pentagons out so as to allow the light to shine through. The light is a LED that has a remote which lets you control the brightness, color, or patterns of color change.
I basically started with a ring of hexagons at the bottom. The tough thing is you don't know how accurate your cut is until you try to put together five of them in a ring. It took me three attempts before I got the angles to a precise enough degree to let it go together without custom cutting one of them. I found the best technique was to print a hexagon on paper, tape it to the wood with double sided tape, then scribe the hex with a knife and straight edge. I would then cut the hex out on the chop saw. I then cut the bevel of each edge on the table saw. After lots and lots of fussing, the ball came together nicely until the very top when I had to custom cut two of the last hexes to make it all fit together. I then sanded, painted the black rings, and finished with some poly. She gets it in ten days. :)
Gallery
Comments
· Registered
very cool! Do you plan on painting it like a soccer ball?
I can only imagine the amount of hair that was pulled out during the build! :)
· Registered
Wow, very cool. When the kids say "when am I ever going to need Geometry in the real world…" -THIS IS WHY!!! So you can amaze your friends!!
I'm trying to figure out what the glue-up must have looked like. I have enough trouble with straight edges.
· Registered
No. That's it for painting. The black rings along the edges of the pentagons and the lightness of the wood are enough for me to make it look like a soccer ball. I'd hate to hide the wood with white paint.
· Registered
Oh my GOODNESS. This is a wonderful project and exquisite craftsmanship. Your daughter should be ecstatic!
How hard is it to change the LED?
Love this project! If only I had the patience to do this kind of detail work! Maybe when I'm mature enough I'll develop the patience required.
· Registered
Henry, I got mildly lucky in that the LED fits perfectly through the top pentagon. You have to do a little wrangling from both sides with your fingers to screw it in, but LEDs should last 25,000 hours so I think I'm good. ;)
· Registered
Nice idea and well done. Maybe taking a look at my blogs on cutting hexagons and polygons on a table saw would relieve some of the fussing. Not sure about that, but I'd be interested if they would help in that way.
· Registered
Thanks Don. I read many blogs first. It's one thing to know the bevel has to be at 20.9 degrees for hex to hex joints, but another to coax your table saw into making those cuts with precision and repetition.
· Registered
Very nice and very unusual idea, first time I have seen such as a lamp. I have seen another such similar "thing", meaning symmetrical and with many facettes, essentially spherical in shape but it was a masterpiece of welding and the maker made the pattern of the facettes to stand out by using the welding material in the joints of another material than the facette/side material. I have seen nothing such like in wood though. Excellent and very, very nice!
I have a question: You mentioned that you used a LED-light inside which you could adjust, amongst other, the color of. Would it be possible for you to give some details regarding the model/maker of the LED-light? Where did you found that particular LED-light you used for your project?
I am working at a workshop where they do advanced things (prototyping very often of design ideas) in wood and also in metal. I am located in Stockholm, Sweden and have never seen any LED-lights of that type/size/design that you describe here in Sweden before (LED-lights that are adjustable in so many ways). To buy such LED-light from abroad for me is no problem, but where to find? I am planning to build such a "nightlamp" myself but would have to get an idea of the LED-light's size first to decide what dimensions the final assembled "nightlamp" could have.
Sincerely
