Showcase cover image for Tragedy somewhat averted vase
Project Information
This is a piece of 300 year old redwood that I was given by a friend of mine recently. after hollowing the redwood and fitting the top piece of ebony, I planned to delicately finish the hollowing around the rim when WHAM …er, guess that wasn't so delicate after all! Much loud yelling and hoping later that the neighborhood kids were not in earshot of my garage given my language.
I've had a few blowouts before, but it's particularly sad when you have a piece of wood that is really special. Even before I broke it, I was thinking "This is fairly high risk…you need to be very careful right about now…no risk, no reward…go for it!)
I almost lopped off the top to make something else (with deja-vu like memories of several ashtray size pieces in the early days of turning), but decided to try and stitch it back together as best I could. I was fortunate that it only broke into 5 pieces and I've done this a few times before, but I was more patient this time and took over 2 hours just gluing the 5 pieces back together. I used tiny amounts of fine sawdust from the different woods to fill the small gaps.
The last photo shows how the final 2 pieces went together, and if you look closely in the 3rd picture, you can see the remaining seam now that all of the finishing work is complete.
We should probably start a blog on the topic of "I broke it, but I'm happy with the final repair job" :)
Let me know what you think!
Richard
Gallery
Comments
Bugger @#$%^&*(
Richard, I think it would be hillarious to have a blog on "what you dont normally see" that ends up in the firebox. Auctally you could have
1 on saves
1 on definately the fire box.
It's always the treasured piece of timber that gets the bad deal (have you noticed that)
BTW, nice job on the turn & an equally good job on the stitch up, lovely piece of timber.
What were you planning to do with the base?
Keep the faith, there will be more to test your calm :)))))
Way to go. Nice save. You did a great job and no one would notice if you did not call attention to it. You just have to try and it worked!! Thanks for sharing. It will give others ideas to saving pieces that come apart while turning….........Jim
Thanks everyone!
@Peteg, I almost decided to hollow from the base end vs. the neck end as I knew the tight neck would present a challenge and/or limit the ability to hollow. In the end, I did it the traditional way and the base is finished in pretty basic manner. I used a glued on tenon to get as much height out of the chunk of wood as possible (you can see it in the 3rd picture). I then turn off this tenon and made a small indention on the base - need to get into the habit of taking a picture of the base.
-Richard
Beautiful vase and great job saving it. If you had not said anything I would not have known it was busted at one time! Fantastic job of finishing!
Erwin, Jacksonville, FL
