Project Information
Toy airplanes for a nephew. Each body is made of basswood. The basswood was lightweight and easy to shape using a shinto rasp and some hand sanding. The wings and tails are made of ash and cherry offcuts I had available. These were finished with real tung oil. The paints were child safe water color paints. On each plane there is hole drilled for a pilot. I epoxied a magnet in each hole. Using a 1 inch dowel and a hobby store wooden ball I made three pilots. I drilled a small dowel hole in the dowell and ball to connect them. The base of the pilot then had a hole drilled and a magnet epoxied. Each pilot stays firmly in the plane. More pictures to come after pilots are painted.
