Showcase cover image for Tile Table Tray
Project Information
Approximately 9"W x 14"L x 1-1/2"H.
Fumed white oak and jatoba.
I was rummaging through my wife's "reject" collection and pulled out this 8" x 12" tile she had fired a floral pattern decal onto. The problem with it was the decal got slightly overcooked and the colors faded a bit. I had made various trivets from these in the past but I thought this tile would be perfect for some tray handle ideas I had bouncing around my noggin.
Instead of my usual finger holes through the end, I decided to leave the ability to pick the tray up from beneath. Not wanting to keep it too simple, I also wanted some angles involved so the ends slant in 15 degrees and out 10 degrees.
This is what I came up with as a test, an interior arched end piece joined to an outside piece of contrasting wood with a gap underneath for fingers. These two pieces are joined in an "A" configuration.
I also wanted to avoid excessive end grain exposure so I rabbeted the side rails deeply into the end pieces. to lift it all up from the table, I placed corner feet made from jatoba.
The tile is dadoed into the sides and the underside is covered with 1/4" lauan plywood.
Not really designed for serving, this is probably best used as a table centerpiece to hold salt/pepper, napkins, etc.
A few things to change for future versions, but the concept worked!
Thanks for looking 8^)
Gallery
Comments
That looks great! The features all play together well - the shapes, wood choices and even the tile all tie in.
Premium Member
thats just beautiful splint,your tray really shows off the tile quite well.nice work on the joinery also,great craftsmanship buddy.
Very nice design and workmanship. I think you will be very proud to use this. I like your wife's tile too, it goes perfect with the tray.
Thanks fellas!
It feels good to get some ideas turned into reality, warts and all 8^)
You two make a great team! Both the woodwork and the tile are gorgeous and the two of them together is a great match.
Jon
Super build, like the original design with the handle aspects.
Jatoba is a nice wood to work with, as long as its stable.
Thanks Jon 8^)
Brian, I get my jatoba as unfinished "Brazillian Cherry" flooring. Price is cheap, its dried, and its defect free.
The 5" wide stuff has enough meat so I get slightly over 5/8" thick after removing the back side grooves and perfecting the surfaces.
WOW…That is an elegant tray, Bruce!!
Cheers, Jim
That's really beautiful. Nice style.
Very nice from so many angles.
Great project!
Just another terrific design. I don't think I've ever seen anything you make that doesn't impress me. Thanks for the inspiration, I learn something new from almost all your projects. Congrats on another DT3
Superbly built.
I realy like those angles and curves
Nice job and congratulations on your 'Daily Top 3' award.
