Project Information
A maple came down this past winter across the path to our summer camp in Maine. I cut it up for firewood and started splitting it when I found it was Tiger Maple. I could not just burn it so I saved a few sections.
This spoon is made from that tree.
I roughed it out with an ax and shaped it with a combination of gauge, hooked knife, spoke shave and straight knife.
This is the second spoon I have ever made and I think it is a big improvement on my first one.
After shaping the spoon I baked it at 350 degrees for about an hour.
Finished with Mineral Oil.
Gallery
Comments
Beautiful spoon. I love the shape!!
cheers, Jim
Excellent work!
Claude
Fantastic! Only those who have tried realize how difficult it is to make a nice shaped spoon.
[This may be a dumb question but I'm new at this] Why the baking at the end? If that's to dry the wood, why is that not done before carving?
Metalbot,
Not dumb at all. I've never carved anything but I do like to find a few board feet of something special in a down tree. 350 is way higher than needed if the concern is insects, so ithe bake is probably to dry it out. I would think its easier to carve it while it's still moist, at least I think it is for turning small bowl blanks.
Redtail,
I love the form that you have gotten on this piece. It's hard to believe it's only your second spoon. Did you bend the curve of the handle, or is that a result of your carving.
-JD
The baking may also be to help draw the mineral oi a little deeper into the wood, although usually a bout 4 minutes is enough for that.
I baked it prior to applying the oil. It is supposed to stabilize the wood so that it does not get effected by moisture. I think it is called catalyzation. I read about it in a facebook spoon making group. It chemically changes the wood to harden it.
I did the carving while the wood was green and boy is that easier than dry wood.
I did not bend the handle. I carved that out of the block. My first spoon was made from a 4/4 board so I did not have enough wood to allow for a curve.
Great work on that spoon! It would become the wife's favorite in our kitchen I'm sure!
I gifted this to my aunt and refuses to use it. She just has in on display. Personally I think she is missing out.
