Project Information
Solid red oak and walnut living room tables built for the same home as the dining table also described in My Projects. All tables feature leg assemblies where the horizontal pieces form part of the top and are connected to the vertical pieces using bridal joints. Finish is Minwax natural oil stain (#209) to highlight the grain followed by sprayed waterborne lacquer. Result on walnut is not as nice as the polymerized tung oil I had used on the dining table.
The end table features a deep drawer that fits into notches made in the top section of the front legs. Version 1 of the design actually had the drawer fit between full size legs (3" wide faces), which did not make for a very pleasing look. By notching the legs the drawer could be widened by 3". The drawer sides are connected to the front with a rabbet joint reinforced with a couple of pan head solid brass screws recessed 1/32" into the wood then filed flush to the surface of the side to produce fake brass plugs. This is a design detail I saw on a piece of Greene & Greene furniture. 18" wide x 24" deep x 22" high.
Coffee table is 18" wide x 38" long x 18" high.
Gallery
Comments
· Registered
Brian said: "It must have been tricky to file the brass flush w/o marring the drawer sides. How did you accomplish that?"
The file I use was fairly fine so it did not mar the sides badly. A little bit of sanding with 180 sandpaper took care of the file marks. One problem though is that the brass filings lodged themselves into the large pores of the oak and I could not get them out. So the wood around the brass "plugs" kind of looks dirty. I think if I had sealed the wood with shellac before filing I might have had a better chance of getting the filings out.
· Registered
I'm still waiting for a blah project from you Senomozi , But I dont think it's going to happen! great tables and super cool design.
· Registered
Really cool designs. They look incredibly solid. Nice joint-work as well.
· Registered
Beautiful job on the design and the joinery!
· Registered
Very nice - i love the bridle joints
· Registered
Nice tables. Maybe some masking tape would have helped with those filings.
· Registered
Nicely done! I have always liked the look of oak and walnut together. I also like the professional looking photos as well.
Great job!
· Registered
Very nicely done. Neat, and I like it!!
The contrast in wood is realy nice.
· Registered
Well done! keep up the good work.
· Registered
Very nice design and execution. I will add this to my favorites and probably use some of your ideas. Thanks for posting! I may use cherry to see how that looks. For what it's worth I always think an odd number of pins in the sides of drawers look better than an even number. Whatever. Beautiful.
· Registered
Just a beautiful project expertly executed. This must have been time consuming but such an outstanding result! I really admire your work.
