Comments
Thanks Larry, gotta keep the family happy :)
Keeping family happy is a challenge by itself. I usually fail at this.
Good looking boards though
Nice set of boards, what are the final dimensions… about 5×8"?
Thanks Monte ;)
Thanks Ned they are 10"X 12"X 2".
well, I was 'close' if it was 1" thick I would have been in the ballpark.
Real close Ned they had to be BEEFY just like the family :))
Looks great. I was working on some cheese slicing boards this week end and forgot to plan propely for the slicing arm so I ended up with some designer firewood. Likely I can savage some of it. The boards look awesome I may use your pattern to remake the slicers.
looks great and everybody is happy. they're all the same
Nice job these are cool.
great looking boards. can you fill me in on how these were glued up? have a problem with depth perception. thanks
Hey Albe have you considerd putting
feet on those cheese boards and calling them trivets ?
Doordude thank you
A1jim thanks also
Wiser this was a single glue up starting with two inch thick stock, I used the two three four three method that I learned here on this site from Mclean Va . And that simply means that the first board is two inches wide the second is three the third is four and the fourth is three inches wide. Glued together in a set long enough so that when I cross cut them I had enough to put three boards together and glue them up. I hope this helps and please feel to pm me if I can help more.
Great job matching the grain to make that continuous wave across the board.
Thanks Kevin
