Project Information
I had built myself a Vdrum sander but also wanted a thickness sander but didn't have room for two machines. Then I saw someone on LJ's built a dual thickness/vdrum sander and that was it. I had to make one.
I started with making the 20" drum from 4" ABS pipe and 3/4" shaft. Made jig to true-up the drum with the router. It worked perfectly.
I purchased a used manual treadmill for the feed mechanism. Ended up making new frame for it.
The motor is a 3450 rpm 1.5hp from a dust collector I had given to me free. Reduced speed down to 1725 rpm by using a 2" and 4" pulley's.
Lift mechanism is simple threaded rod. The rear of feed mechanism has holes in frame that allows me to adjust thickness of sanding if required. To feed pieces through just turn the handle. I find that I can feed it through and then turn handle backwards and forwards several times without adjusting height.
Dust collection is easily moved from top to just sit on conveyor for use as vdrum sander. I made a fence when in vdrum mode so I can also use it as edge sander or even like a jointer.
Whole unit was put on old vdrum stand.
All in all this sander works fantastic and is accurate within 0.05mm on entire width of 20" drum. Thanks to all LJ's who posted similar projects for me to get ideas.
Here is a quick video of it.
Gallery
Comments
That is a very impressive piece of workmanship! And useful to the max!
Great build. I've got an 18 drum sander half way done. Im trying to find a reasonable motor and pully setup without breaking the bank. I think I may add a vdrum sander platform to the top.
Wow, you did an amazing job on this. I would sure love to have one.
Nice Build !! But what does it do for you, that your Vdrum Sander can't do ?
Thanks for the comments. The reason I wanted this sander was so I could thickness sand wide glue ups. I only have a 13" planer so anything wider was a pain and I am not good with hand planes. I also wanted it to sand boards flat and not get chip out like a planer will do. But I also wanted the capabilities of the vdrum. So I feel this accomplishes both jobs without sacrificing shop room.
Thanks
Manual Treadmill for feeding??? GENIUS!!! im definitely going to upgrade mine now. but why not trying to motorize it? you can easily attach a screwdriver to that, and im sure it will do the job.
Are you using a velcro sandpaper?
My drum sander project has been on the back burner for a while now. I am needing to get back on it. Thanks for the motivation!
My first thought on reading the treadmill line was that you were powering by running! Even though that's not the case this is impressive!
Very impressive build getting both sanding styles into one machine. Great execution of a great idea!
Hello and welcome geekwoodworker
Very nice built
One machine for two works very nice idea
Thanks for sharing
I have thought about powering the feed mechanism but like the idea of just going forwards and backwards with one piece using manual turn handle. But may go with it in future. Made it so I can upgrade easily. Yes the drum is velcro and I find I use mainly 150 grit sand paper for most jobs. Used 220 grit to take paint of some old table legs and it still worked excellent.
Thanks for all the nice comments guys. I joined LJ's so I could inspire/help with ideas just as I was. So thanks again to all those who post thier projects for others to learn and get inspiration.
Forgot to mention to all that I had to add 1" anti-slip tape to the conveyor as it wasn't grippy enough to hold pieces in place. During the first few tries one piece flew out at high rate of speed and hit the wall. Fortunately I was standing beside the machine turning the crank handle. Would have hit me in most unwellcomed spot.
No pieces have flown out since. But I still stand to side.
My future project. Always nice to steal some ideas.
Congrats on the sander. You mention making a pvc pipe drum then truing with a router, weren't you worried about getting the wall thickness too thin? Did you reinforce the middle with wood discs or anything?
Thanks and it works better than I thought it would. No vibration and quiet. The thickness of the ABS pipe wall is 1/4" and I only removed about 1/32" or less. I think ABS is thicker than PVC. So no worry of it being too thin. I reinforced the inside with 3 discs. One in the middle and two on outsides. The discs are made of 18mm russian birch ply. I glued two pieces together to make them 36mm thick for better stability.
