Project Information
Every year, I donate a "work of heart" to a local charity to silent auction. I also wanted to find a piece of wood that has a knot in it so I could compete in the winter contest. The base of this box is cherry. The lid is purple heart, ebony and osage orange.
As usual, I began carving with the angle grinder after I cut the shape out with the bandsaw, I started refining the curves with the grinder and smaller hand held grinding tools. I loved the integration and transition of a top that matched the shape of the bottom of the box, but changed and worked together with the leaves stemming from the center top of the heart. This is finished with sanding to 4000 grit. I finished the lid with wipe on poly and the bottom (cherry) with tung oil. The cavity of the box is not cut with the band saw, but actually carved out of the solid block of cherry.
The handle is carved to look like a slipper and is so soft and tactile that you want to touch it and lift the lid. I cut a sliver slot for the "heel" and dowel pinned the "toe". This was a particular challenge, as the first handle broke when I was drilling for the dowel pin.
I hope you like it. I always enjoy feedback.
